3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a awsome match rocket
Step 4Making the rocket
making the rocket
  • last photo ←
now get the foil and the battery
and put the battery like this
then start to roll the foil up
about 8 rolls should do it
chop the rest off
chop off the exess on the top and bottom
then twist the top
then twist to keep it nice and tight
then pull the battery out
until it is fully out
the rocket will still be hollow inside
2 comments
Apr 2, 2012. 7:54 PMmykiscool says:
The commenter below me is right. I would recommend using a chap-stick case, a small wooden dowel, or a pencil instead. If you must use the battery put electrical tape over the positive terminal.
Jun 10, 2010. 12:19 PMskelly7447 says:
if you touch both terminals of the battery to the foil, it will short out and heat up. It can overheat and explode!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ethanman101
