Scott had always wanted to make some sort of ball bearing rollercoaster and we thought we'd post up the results of his first testing and building sessions.
The idea was to make track for ball bearings (or similar) out of something that was fairly quick and easy to work.
Scott found that mains cable copper wire was perfect for this, go to the next step to see a list of ingredients for this project and get cracking.
It is assumed that you have access to a workbench / desk and that you can use tools like soldering iron, wire cutters and so on.
Remove these ads by
Signing UpStep 1Ingredients
- Ball bearings (we used 5mm)
- Battery drill/screwdriver (ours is the cannibalised motor from an old one)
- Small drill bits (that match the diameter of the wire you will be using)
- Mains wire (we ended up getting a big roll but you can use the grey sort, often easy to get from skips or lying around. You'll want the stuff that is quite stiff, we found 2.5mm squared core to be best)
- Pliers / wire cutters
- Soldering iron + solder (we ended up modifying our soldering iron tip for best soldering)
- Small motor (ours is from and old zoom lens, you could maybe take apart an old CD drive to get the tray motor or similar - post up what you use)
- Spirit level/s
- Chipboard / ply board (for jig and for mounting the rollercoaster)
- Matches (for jig)
- Glue (we used hot melt glue gun and some wood glue)
- Sharp knife (Stanley or similar)
Once you have this lot, you can get making!
i hope to make one when i have some free time
thank you for your comment. We do have a new design using only one motor - we haven't quite yet put an instructable together for this but can share some images:
http://twitpic.com/4846hm
http://www.flickr.com/photos/nottinghack/5520954871/sizes/l/in/photostream/
http://www.flickr.com/photos/nottinghack/5520943595/sizes/l/in/photostream/
The new lifter works by forcing the ball bearings vertically up a 'cage' - rather than using the 'archimedes screw' type technique.
We can't get any more photographs yet as the sculpture is away on holiday but once we get it back I'll try to get some more pictures of the new ball lifter detail.
we would suggest that if you can't solder copper then this project may be a little too much of a challenge. Have you tried using flux and/or a more powerful soldering iron?
Good luck + let us know how you get on.
I have tried to solder the wires, and have had no luck. My soldering iron is electric. Do I need to use a gas like butane? Can you give more detail on your equipment and methods?
if you want to get a torch for cheap, dealextreme's a good website. their stuff's a little cheap (my ignition system broke and I have to use a lighter now), but the torches seem to work fine.
Also try to apply quite a bit of pressure with the soldering iron - pressing hard should help to transfer the heat.
As maxwelltub says flux can also help although we didn't use any - just flux cored solder.
Good luck and stick with it! Let us know how you get on.
Also well done for sticking it out, always nice to have a few half done things lying about to be able to crack on with!
Nice idea for the shrink tube / motor connection. it would be cool to see some pictures of your ball run, post them up or send them over if you're up for it.
I'd like to add a magnetic transfer mechanism that picks the ball off one track and sets it on another; probably use a rotating arm that goes just over the top of the ball at a stopped postition (or maybe in the middle of a track, so it's random) and then past a blockade that scrapes the ball off while it's above the other track. Any thoughts on that, or other mechanisms to add?
Using a motor with long rubber belt from an old computer printer with two very small neodymium magnets stuck onto the outside of the belt at halfway intervals.
One problem that had to be solved was a mechanism that prevented more than one ball bearing stopping in the pickup point. It was possible for the magnet to pick up multiple balls fouling the lifting.
Also when introducing magnets into the track we found that the ball bearings got slightly magnetised, affecting how they rolled on the track. That's the reason for the shaft lifters.
Let us know how you get on if you try the magnets, you've got some cool ideas.
First tip is to use side cutters with one flat edge - meaning a cutting side with no bevel to it. This gives you better flat ends to your track sections. When cutting like this, sometimes the copper won't cut perfectly. Try twisting the wire off just after cutting, rather than pulling apart to reduce the shearing.
Next, when joining two track sections:
Roughly solder one track side together with a quick solder join to hold it the two pieces together.
Next, line up the other track as perfectly as possible, using the other solder join as a lever / extra support to hold the second (and better) solder join.
Once you have a decent join, you can touch your soldering iron on the first temporary join and reposition, using the better join as a guide.
This technique should allow you to get usable solder joins. If you are struggling after a good few attempts you can try overlapping the track joins. This will be a bit easier to solder and you can always try the butt joins later. Soldering is rewarded by practice and patience :)
Good luck and let us know how you get on.
All the wire I've across is too weak, or multi-stranded.
I did a test to see if I could do this with a simple coat-hanger, but the solder wouldn't adhere to the metal :P
