3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a bike headset press & install a headset
Step 4Install second headset cup
For the second cup, you will need to use a different plastic spacer setup in order to be able to get the spacers out after you put the cup in.
3 comments
Aug 12, 2010. 2:05 PMmedusa569 says:
It would be nice to get an idea of approximate pip needed..frankly all I see is basically what look to be like a about a foot of 2" pvc. Also what is the round metal showing on this pick?? I though you would have the pvc spacer on each side of the cups so what is the metal?
May 22, 2006. 1:34 AMPrometheus says:
NO NO NO!!! Never pres against the inner diameter of the cups as this can not onoly warp them but also potentially damage the case-hardening of the cups themselves! ONLY press on the outer ring of the cups such as using a bolt-and-washer design. Ideally in this photo the lower piece of pipe should not even be in this pic, it would have been better to leave the wood to handle the pressure DO NOT follow the above example or you may damage your lower, and mos5 critical, headset cup. Press flat against it's outer edges only...
Oct 27, 2008. 9:33 PMtheopowers says:
The Park Tool version used in bike shops everywhere presses on the inner cups.
Oct 28, 2008. 9:14 PMPrometheus says:
Yes, but that is a tool MADE for the job. When using something other than that, it is best to press on the outer lip of the race.
NO NO NO!!! Never pres against the inner diameter of the cups as this can not onoly warp them but also potentially damage the case-hardening of the cups themselves! ONLY press on the outer ring of the cups such as using a bolt-and-washer design. Ideally in this photo the lower piece of pipe should not even be in this pic, it would have been better to leave the wood to handle the pressure DO NOT follow the above example or you may damage your lower, and mos5 critical, headset cup. Press flat against it's oputer edges only...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
