Introduction: How to Make a Camera Support System From a Child's Skate.
Picture of How to Make a Camera Support System From a Child's Skate.
After my shoulder surgery I realized that i need it some sort of device to hold my camera. I was shooting sports so a tripod was out of the question.
To make things worse it was my right shoulder that was injured ( 98% of the cameras manufactured are design for right handed people.)
Anyway I started to look at photo catalogs for a solution. Mainly what I found was that I would have to spend $200 to $300 for a shoulder mount support, so I decided to see If I could make my own .
Step 1: Teardown
Picture of Teardown
Materials
A kid's skate
A flash bracket (Preferably Metal)
A few bolts to hold everything together
Tripod head parts
Velcro straps
One sock
Foam
A wired remote control (the only item I bought about $28.00)
Tools
Allan wrench
power drill
The first step was to remove the wheels
Using a power drill I remove the rivets from the toe portion of the skate.
Step 2: Building
Picture of Building
Next step we will insert a flash bracket that will serve two purposes.
It will be a handle and a base for the tripod head .
The flash bracket fit were the wheels were and it was secure with some bolts.
Step 3:
Picture of
I secure  parts from a minii tripod to the flash bracket.
Step 4:
Picture of
I filled the heel part of the skate with foam and added a sock to hold it together.
The remote was held in place with a Velcro strap.
This turn out to work better than expected I was able to follow the action and shoot using only my left hand.
I like it enough that I think I will be using it after i get my right hand back.
quepez (author)2010-01-11
pero que practico e ingenioso esta muy padre carnal
mrdepo96 (author)2009-10-11
 you don't look too happy in those photos... Awesome idea though!
Frivolous Engineering (author)2009-10-09
Hey, great idea!
gmjhowe (author)2009-10-09
 I think the use of a skate actually kinda makes it look like a store bought one. Im planning a normal style rifle mount myself. I think you did a great job of producing a product to fit your need.
The wide selection of flash brackets, and such make for great components.
gmoon (author)2009-10-08
Very resourceful and well made (rated this high.)
(...although I personally would have used a monopod...)
cattan (author)gmoon2009-10-08
Thanks
Yes a monopod could work if you are standing in one spot.
I am usually moving around to much, shooting at low angles or chasing the action.
gmoon (author)cattan2009-10-08
I never had a problem running around with a monopod... easy as can be. Suit yourself, of course.
Generally, for "big glass", a monopod is a much better idea--using the tripod / monopod socket on the lens, rather than the camera body. Lens mounts can't handle the strain when using a 300mm or 400mm f/2.8. They are much to heavy, and will damage the mount.
(I still like your shoulder mount, though.)
I agree with you but i am not lucky enough to own a big piece of glass.
Also remember i only have one working arm , My left arm to be precise Using my contraption just feels more comfortable for me. Thanks
About This Instructable
11,358views
15favorites
License:
More by cattan:Iphone Camera DeluxeGarden Ornament and Bird FeederHow to make a camera support system from a child's skate.
Add instructable to:
