loading
Step 6: Finishing the Shirt! (Part 1)
Ok now comes the most confusing part. For this section of the instructable, I scanned in drawings of the concept in order for it to make more sense.
Part A: Make two pieces of maille that are 3-4 inches wide. They should be as long as the distance from the bottom of the sleeve to the bottom of the shirt. Use these two pieces to connect the front and back halves of the shirt. These pieces should NOT be at all connected to the actual sleeve. Check picture number one for clarity in this step.
Part B: Make 2 different pieces of maille that are as wide as your sleeves are long. These pieces should only be 3-4 inches tall. They should look something like this:
The left to right length is governed by how long you made your sleeves. The up and down length should be the same as the left to right length of the pieces made in part A.
Now connect this piece to the two sides of the bottom of your sleeves. Do not connect this piece to the piece from part A that is already attached to the shirt. The drawing makes a lot more sense so if you are confused look at the picture for part B.
Does anyone else get the eulalia reference?
I want to make a chainmail shirt. Assuming I am using 16 gauge jump rings and a size 0 in women's clothing, around how many rings would i need?
<p>I started trying to make a shirt and realized I prefer to work from a hanging position. I built a frame that would allow me to not only build my shirt but I also incorporated a setup on the bottom to make the rings. Using the drill I wrap the wire around a 1/2 inch steel pipe. All told I put about $45 into the frame including the hardware and the lumber. I didn't have ,uch of a plan before starting so I had to improvise the support for the spool and the &quot;legs&quot; out of scrap wood but hopefully this offers some ideas for people who might be getting ready to try a shirt. Overall dimensions are 3'X4' so I can either work sitting on the floor or in a chair.(So I can work on it while watching tv.)</p>
<p>This is awesome! I`m trying to find some good places to get my rings, so I was wondering where you got yours?</p>
<p>Do you have instructions for a shirt that doesn't have sleeves?</p>
hey guys, do you know if 17 gauge aluminum wire is fine for decorative maille?? also, will teh stuff meant for electric fences make everything it touches black??
&nbsp;with fencing wire it does turn your skin black if you play with it for while but ive been trying to find a way to combat that by putting the&nbsp;finished&nbsp;project (or just a heap of rings) into a sand tumbler very&nbsp;similar&nbsp;to what you would use to polish bullets im going to make one out of a bucket and an old rolling platform. im hoping that will polish the rings and also clean all that black crap from the rings. ill post an update soon<br /> <br />
Tumbling or polishing is a temporary fix for black ruboff from aluminum. The best solution I have found to prevent it is to use anodized aluminum.<br><br>It does cost more, but is so worth the quality. And it doesn't have to be a coloured anodize.
here we go it took me 12 long months
nice job!! some work gone into that, er! how on earth do ya get it on and off LOL!!!<br><br>mick
to get it on you need to put your arms into into it, grab the inside of the sleeves then put your arms straight above your head and flick your head into the bottom, then let it go so it falls over you, then you need to do some bounces so that it settles. Then taking it off you need to touch your toes wand then wriggle your shoulders until it falls onto your feet in a big pile, its not very dignified... or graceful
And this, my friends, is why squires were invented. :-D
LOL!!!!!!!! would have to make it extra large and get a wench to help me drag it off,
NICE!!!<br>
COOLL!!!! only thing im doing differently is im going sleeveless
very nice! what are the specs on the ring size, gauge, and material?
my spindle was 10 mm my wire was 3.5 mm fencing wire
And now we all know why tabards are so popular. Because honestly, I can do the chain mail. But I don't think I can bring myself to rip it open and add more chain mail, much less in an actual drawing.
A good tactic is too make a panel with your design first, then simply add it in while making the shirt. No need to reweave, and it's easier to work with.
Do you know how many rings it would take to make a much smaller shirt? How big is the shirt in this instructable?I'm probably going to need something like half this size. Do you know if there is a better way to determine how many I will need than just halving the amount suggested?
If you intend to use the same sized rings as the poster (16g 1/4&quot;), then you are looking at approximately 3100 rings per square foot.<br><br>My advice is to make a pattern based on your measurements, then calculate the square footage.<br><br>I suggest purchasing/making 1-2000 extra rings, in case you need to make adjustments.<br><br>Good luck. :)
Use the Pop Bottle Chain Mail for this. It would be quicker.
&nbsp;Quicker? &nbsp;Yes.<br /> Better? &nbsp;No.<br /> <br /> It would fall apart unless you solder each gap together. &nbsp;Plus it wouldnt function as armor, it would only [kinda] look like real chainmail.<br /> <br /> You also have to consider, how long do you think it will take to collect thousands of pop tabs?<br />
<p>I ended up making it with pop can tabs, although it wasn't expensive at all. There are problems with it, first, it doesn't look as nice as real chain mail . Second, it comes apart somewhat easily. Third, it's near impossible to keep from tangling up. My goal is to soon make a real chain mail vest.</p>
&nbsp;Why would we use it as armor unless we are in a renaissance fair or went back in time?
&nbsp;Well, in all fairness, I am part of a renaissance group, and considering we actually use live steel, real armor is always a nice thing to have.<br />
The steel is alive? Fascinating! What does it eat?
probably you if your not fast enough or dont have Armour! my undestanding of a live blade is one that will cut! sharp in other words,
Like live ammunition
troll harder bro
lol
Oh, it took me about two weeks.<br />
&nbsp;seconded
I made some poptab maile and it looks awesome but it definately is NOT practical because it falls apart i am working on improoving it by taking and combining this type of chain maile and poptab maile i am also working on dragon scale armor<br />
But then it wouldn't be as flexible (i think). Although the pop bottle chain maille is good for like braceletes.
<p>How big is the shirt when finished?</p>
<p>size is based on measurements that you take from yourself, so in theory it will fit you regardless. I would recommend adding an inch or two to the chest measurement, so that your underclothing will be accomodated.</p>
<p>Took two months, and I'm very happy with the result, though some fitting is required. Having been making it for so long, changing it's dimensions aren't such a big deal. In fact, I'll be gradually increasing it's length and sleeves over time until I have a hauberk. This guide is a great for the relative beginner, though bear in mind that there are more advanced examples of byrnies made in pattern form that would have a better fit.</p>
How do you do the 45 degree triangle?
Chain Maille is the armor of choice for the impending Zombie Apocalypse.
This instructable is awesome. I couldn't have made it without it. Do you know a good way to colour the rings? I'd like to make mine a bit darker and possibly colour my inlay rings
When you put the rings into fire or something like that, it makes the rings darker. I don't know if that's permanent though. for the inlay, I used copper wire, first took the insulation off and then put the wire in my jig. I hope you were helped by this reply.
Great instructable, it's helping me a lot in my build, it's not going really fast though, but I have a technique that is faster than the normal one (I think) i'll make an instructable on that subject. I'll show some pics of the finished shirt (if it ever comes to that)
Why is it necessary to add other stripes of chain mail to the side seams? Can you not just connect the front and back panels together?
well u could, but unless u made it a size or 2 bigger than yourself, it would end up being too small.
Hey, <br>Thanks for the awesome guide, I just finished my first shirt thanks to you. It looks awesome, I'll have to do a few touch ups here and there because its a bit too big in places but I'm sure I can manage.<br><br>Thanks again.
i don't feel like making one but i would buy one for 100, 125 bucks if you put some on ebay.
Try like 200-300 at least for a nice, handmade shirt. Although, the point of this site IS DIY. Meaning, do it yourself. Buying it on eBay kinda defeats the purpose of Instructables. Trust me, if you do it yourself, you will like it so much better.
unless it's aluminum. you are not likely to find a maille shirt for that price anywhere. but if you want an aluminum one, they have them at thinkgeek.
About This Instructable
320,074views
673favorites
License:
Bio: I enjoy building and inventing; I love creating new things and improving on old ideas. I am a student at BYU and am studying under ... More »
More by ineverfinishanyth:DIY Metal Stamping Bed in a Box Tactical Multitool
Add instructable to:
