3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a cheap and easy vaporizor
If you smoke, you know how bad it is for your health. Vaporizing is the cleanest, purest way to get the effects of what you are smoking, without the harmful toxins.
This vaporizer was built from household objects and requires very little tools.
Step 1Materials....
Materials....
Materials needed are:
Heat gun w/variable temps
Martini shaker w/ strainer and lid
One foot 3/8 clear tubing
Threaded hose fitting
Open/close valve
Some smoke
Tools needed:
Drill
Drill bits
7 comments
Feb 24, 2010. 8:23 AMnevssons says:
 Cheaper and easier:
Sep 16, 2011. 8:03 PMDr.Duckhunt says:
thats sweeet. very similar to mine. i just posted it.
Aug 10, 2011. 10:35 PMspacesaver says:
As the product of choice is not burned, rather the moisture/essence of the product is extracted, there is little of the hacking and coughing associated with traditional smoking. And yes, the cooling of the vapour makes inhaling alot easier. As an added bonus, the vapour, not containing smoke particulate, is now quite easy to taste. You can start to taste the difference between products as well as between two similar products but of a different strain.
I would think the idea would be to turn the hot air gun off before opening the valve to inhale, otherwise you are still inhaling a hot vapour which is being forced down your throat by the air gun.
Aug 17, 2010. 7:36 PMreidzuk says:
Try adding ice cubes to the part that is meant to hold martini mix. (The chamber where vapor builds u could also call it). that way it will cool the vapor as well as putting it in the freezer.
Feb 23, 2010. 10:34 PMozone629 says:
Thanks for a good starting point to improvise and devise something even more user-friendly and efficient . An adjustable heating element somehow encased in glass and a vapor-cooling apparatus would be worthy of time & resources applied....I'll post my finished product should it come together properly in the lab.  catch me L8'er
Sep 22, 2009. 5:13 AMxaviero says:
how to use it ? is it more convenient using such like mini exhaust fan ?
Dec 24, 2009. 10:59 AMKg703 says:
by the looks of it, you put the hose in your mouth, and as the heat gun heats your item of choice it vaporizes in the shaker then opening the valve allows the vapors to come out, just a guess. and the cooling helps with inhalation i suppose?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:durtbikedave
