Well with this project you can build a par 46 can for about $10-15
Remove these ads by
Signing UpStep 1Breif introduction
The size of par cans are measured in Par's. 8 "Par's" is 1 inch.
Eg. 64 Par is 64/8=8 inches
My Par can is 46 Par (do the math) and you can make any size using tins from anywhere
Most lamps are measured in 1/8's of an inch. often this is preceded by a letter or series of letters that tell you the shape and size.
for example that old four foot long florescent lamp over your workbench likely has a "T12" noted on it, that "T" stands for "tubular'" and it is 1.5" diameter.
the newer shop lights may be T8 or 1 inch
The length of the tube is in normal inches.
That 100watt lamp in this project appears to be a typical "A" or pear shape
What type of 100W bulb did you use?
L
L
I only used a standard bulb because thats the socket i had, if you can find a socket for those floods you can use them but make sure you have appropriate cooling methods in place i.e. a fan
L
