How to Make a Clothespin Gun - EASY
954
11
Published
Introduction: How to Make a Clothespin Gun - EASY
You will need:
A Clothespin (Wood)
1 Rubber band
Cutting tool
Marking tool (optional)
Step 1: Take Your Clothespin Apart
Simply slide the top clothespin part from the spring. And simply take the spring off. Be careful.
Step 2: Measure the Length You Want
Use a pencil or pen to mark the part you want to cut.
Step 3: Start Cutting
Use your cutting tool to cut the part you marked. Please be really careful.
Step 4: Finished Cutting
Now you're ready to put it all together
Step 5: Attach the Spring Like This
Step 6: You Can Also Cut a Notch So That the Spring Will Hold Tighter
Step 7: Attach the Spring
Then attach the spring. It should look like this.
Step 8: Tie the Rubber Band (NOT TOO TIGHT)
Step 9: Now You Have a Clothespin Gun.
Step 10: Aiming and Shooting
This is how you shoot and reload
Step 11: Malfunctions That Might Happen
If your gun does this, then make the notch a little bit more deeper. Use your cutting tool to do this. Then put it back together. Finished.
Step 12: Enjoy!
Make bullets for your gun. You can also use the piece that you've cut.
P.S- This is my first instructable, so yeah :)
    • Stick It! Contest
      Stick It! Contest
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    2 Comments
    Thank you so much and yes I will be doing more instructables for you guys...:)
    Cool project! All of your close up pictures are really great! I hope we see more Instructables from you in the future!
