Introduction: How to Make a Coin Bank
This instructable will provide a fun and creative way of saving your coins. I made this as a replacement for the boring jar I had been using to store my coins. I hadn't seen it on this site so I thought I'd share.
Step 1: What You Will Need
- (1) .25"x5.5"x36" wood plank
- (1) 11"x14" clear acrylic sheet
- (1) adhesive for wood+pastic (I don't recommend the one pictured because it's messy)
- (1) 1/2" FLAT head plugs
- sandpaper (not pictured)
- (1) box of wire nails
- reciprocating saw (not pictured)
- free font and icons from creative market (optional)
- something to cut the nails with (I used pliers(not pictured))
- hammer (not pictured)
Step 2: Mark and Cut Your Wood
Follow the measurements pictured and make sure to go slow and stay on your markings. The front will need a 7x4 hole cut out so that we can see the coins as they fall to the bottom. On the other sheet you will need to mark a 7x4 rectangle where you will put your nails.
Plan where the nails will go by marking equal spaces between dots. I made rows of three, and staggered them to make the coin bounce off without getting stuck. I don't have the exact measurements but I made them using a quarter (money) to space out the nails.
Step 3: Nail Your Board and Glue on Plugs
Hammer the nails into the holes you marked. [make sure not to put any nails outside of the 7x4 rectangle you have marked]. Once they are in, pull them back out and cut of the tips so that, when put in, the nails are no higher than the plugs. once all the tips are cut, hammer the nails back in. (You can add glue if the nails are too loose.)
Step 4: Cut and Glue Plastic
Cut a 9x5.5 piece of clear plastic and attach it to the front piece. Put a weight on it or clamp and make sure the edges are flush.
Step 5: Glue Together the Front and Back
Put glue on the plugs and put the front piece on it. Make sure the plastic faces towards the nails. Put a weight or clamp on and make sure the edges are flush.
Step 6: Cut Out the Collection Box
Follow the markings to cut out the top, bottom, and the sides. when cuting the sides you want the cut to be angled so that your front is not totally vertical. This will help the bank balance.
Step 7: Make the Collection Box
glue the sides to the top and once dry, glue it on the backside of the front. Put the bottom piece in as well so that the sides of the back stay flush with the sides of the front. The back can be whatever you want.
Step 8: Set a Goal for Yourself
I downloaded a font and some icons off of creative market and printed them out. I taped it to the back and it's a reminder of what I am saving up for. These are from the current selection of free downloads at creative market. The link to both is on this page:
https://creativemarket.com/free-goods?gclid=CNaNyJKL_8UCFdcUgQodnjMALw
Step 9: Save Your Coins!
Thanks for checking out my instructable. Please comment any questions or recommendations you have and I will do my best to get back to you.
Also, this took a lot of work and planning and I would greatly appreciate it if you took the time to vote for my instructable in whichever contest(s) you think it should win.
Thanks for taking the time to read my instructable.
Bedroom Contest
Graphic Design Contest
