Step 10Copy and paste the source code
Example for DIP32 (8mHz)
dim M00 as new pwm(PP0)
dim M01 as new pwm(PP1)
dim M11 as new pwm(PP2)
dim M10 as new pwm(PP3)
dim IR1 as new ADC(PAD05) //ADC object for Sharp Sensor (Front)
dim IR1Result as new byte
dim IR2 as new ADC(PAD03) //ADC object for Sharp Sensor (Back)
dim IR2Result as new byte
dim myChar as new byte //Variable to store received characters
dim S as new SCI(PS0,PS1) //SCI object
dim SPK as new DIO(PM4) // Using Speaker on the SSIM
const ontime = 20
dim duration as new word
Const A2 = 2273 // Music notes
Const A3 = 1136 // Music notes
Const A4 = 568 // Music notes to make sound when robot sees something
dim WLED1 as new DIO(PM2) //LEDs on the wheels
dim WLED2 as new DIO(PM3) //LEDs on the wheels
dim loop as new byte
Const OFF = 0
Const ON = 1
Const FOREVER = 1
Const A = 200
Const B = 10
Const DEL_1MSEC = 1000
sub DelayMsec (in byte milliseconds)
while (milliseconds > 0)
System.Delay (DEL_1MSEC) //Delay 1000 microsecond to make 1 millisecond
milliseconds = milliseconds - 1
end while
end sub
sub stop() // to make motors stop
M00.PWM_Start(PWM_MAIN_CLK,0,250,250)
M01.PWM_Start(PWM_MAIN_CLK,0,250,250)
M10.PWM_Start(PWM_MAIN_CLK,0,250,250)
M11.PWM_Start(PWM_MAIN_CLK,0,250,250)
end sub
sub goback() // robot will go back
M00.PWM_Start(PWM_MAIN_CLK,0,250,180)
M10.PWM_Start(PWM_MAIN_CLK,0,250,180)
end sub
sub turnright() // turn the robot to the right
M01.PWM_Start(PWM_MAIN_CLK,0,250,180)
end sub
sub turnleft() // turn the robot to the left
M11.PWM_Start(PWM_MAIN_CLK,0,250,180)
end sub
sub goahead() // make the robot forward
M01.PWM_Start(PWM_MAIN_CLK,0,250,180) //left dc
M11.PWM_Start(PWM_MAIN_CLK,0,250,180) //right dc
end sub
sub wait3() // my own delays
DelayMsec(A)
DelayMsec(A)
DelayMsec(A)
end sub
sub wait4()
DelayMsec(A)
DelayMsec(A)
DelayMsec(A)
DelayMsec(A)
end sub
sub wait5()
DelayMsec(A)
DelayMsec(A)
DelayMsec(A)
DelayMsec(A)
DelayMsec(A)
end sub
sub wait10() //long delay
loop = 1
while(loop < 11)
DelayMsec(A)
loop =loop + 1
end while
end sub
sub playsound() // to play the notes
duration = ontime
while(duration > 0)
SPK.PIN_Out(PM4,ON)
system.Delay(A2)
SPK.PIN_Out(PM4,Off)
system.Delay(A2)
duration = duration - 1
end while
DelayMsec(B)
duration = ontime
while(duration > 0)
SPK.PIN_Out(PM4,ON)
system.Delay(A3)
system.Delay(A3)
end while
DelayMsec(B)
duration = ontime
while(duration > 0)
SPK.PIN_Out(PM4,ON)
system.Delay(A4)
system.Delay(A4)
end while
DelayMsec(B)
end sub
main
PWM.PWM_Res_PP0145 (TIMER_DIV_16, 0)
PWM.PWM_Res_PP23 (TIMER_DIV_16, 0)
S.SER_Setup(SER_BUFFER_4,BAUD9600) //Setup SCI and allow 4 characters to be buffered
System.INTS_On () //TURN ON INTERRUPTS!
S.SER_Put_string("This is a test ")
S.SER_Put_char ('\n')
S.SER_Put_char ('\r')
while (FOREVER)
IR1.ADC_Start (WAIT, ADC_MODE_8ONCE) // Read value from the front sharp sensor
IR1.ADC_Read (PAD05,IR1Result)
IR2.ADC_Start (WAIT, ADC_MODE_8ONCE) // Read value from the back sharp sensor
IR2.ADC_Read (PAD03,IR2Result)
S.SER_Put_decimal(IR2Result,FILLUP_SPACE) // send the value to the windows hyper terminal
S.SER_Put_char ('\n') // make a new line on the hyper terminal
if ((IR1Result == 25) or (IR1Result > 25))
stop()
playsound()
wait5()
WLED1.PIN_Out(PM2,ON)
WLED2.PIN_Out(PM3,ON)
goback()
wait5()
if ((IR2Result == 25) or (IR2Result > 25))
stop()
playsound()
wait5()
turnleft()
wait3()
goahead()
end if
turnright()
wait3()
else
goahead()
end if
stop()
wait5()
turnright()
wait3()
WLED1.PIN_Out(PM2,OFF)
WLED2.PIN_Out(PM3,OFF)
goahead()
wait3()
else
goahead()
end if
end while
end main
Add Comment
