Introduction: How to Make a Corset (quick + Easy)
Picture of How to Make a Corset (quick + Easy)
Step 1: Materials List
Picture of Materials List
- dress form
- satin tape, 3 mm
- scissors
- pins
- pattern film + pen
- cardboard
- tailor's chalk / dressmaking pencil
- shell fabric (medium weight)
- lining (heavyweight canvas)
- sewing machine
- yarn (polyester)
- plastic bones, 5 mm
- eyelets
- eyelet setting tool
- ribbon
- electric iron
Step 2: Making the Pattern
Picture of Making the Pattern
You just need a dress form, some pins and a satin tape to start making a pattern. If it is your first attempt to sew a corsage: Keep it simple!
Step 3: Making the Pattern
Step 4: Making the Pattern
Step 5: Making the Pattern
I always use transparent film to transfer the pattern.
Step 6: Making the Pattern
Step 7: Making the Pattern
Step 8: Making the Pattern
Now you can transfer the film pattern to a cardboard. Don' t forget  to add 1 cm seam allowance. (sides, bottom, top)
Step 9: Making the Pattern
Fabrics should be cut on a grain. Draw a right angle from the waist line to get the grain. The straight grain runs parallel to the selvedge.
Step 10: Cutting the Fabric
Picture of Cutting the Fabric
Step 11: Cutting the Fabric
Step 12: Sewing Shell Fabric / Lining
Picture of Sewing Shell Fabric / Lining
Sew all pattern pieces together and iron flat afterwards.
Step 13: Sewing Shell Fabric / Lining
Step 14: Sewing Bone Channels
Picture of Sewing Bone Channels
We use the seam allowance to get bone channels. Just sew at a distance of 0,5 cm beneath all dividing seam.
Step 15: Sewing Bone Channels
Step 16: Sewing Shell Fabric and Lining Together
Picture of Sewing Shell Fabric and Lining Together
Now that the bone channels are ready, the shell fabric and lining can be sewn together at the top.
Step 17: Inserting Plastic Bones Into Bone Channels
Picture of Inserting Plastic Bones Into Bone Channels
Step 18: Sewing Shell Fabric and Lining Together
The shell fabric and lining can be sewn together at the bottom.
Step 19: Sewing Center Back
Picture of Sewing Center Back
Step 20: Sewing Center Back
Step 21: Sewing Center Back
Step 22: Inserting Eyelets
Picture of Inserting Eyelets
Step 23: Inserting Eyelets
Step 24: Inserting Eyelets
Step 25: Inserting Eyelets
Step 26: Inserting Eyelets
Step 27: Inserting Eyelets
Step 28: Inserting Eyelets
Step 29: Inserting Eyelets
Step 30: Lacing the Corset
Picture of Lacing the Corset
Step 31: Ready Made Garment
Picture of Ready Made Garment
ChipO7 (author)2017-04-27
Love this! Is there an eyelet hole template that can be purchased? What is the material punch tool called? Is there ever a time that you could use boning around the curve of the top of the corset, or always vertically?
ErinP36 (author)2016-08-14
If anyone else has issues with the bone channels... from all appearances the designer is sewing a 0.5cm seam ON the seam allowance that is pressed open at the back. In other words, after you have sewn the initial seams, press them open and then top stitch 0.5cm from the seam centre edge, on either side of that centre seam line. You are sewing along what would otherwise be the bit you zigzag on to reinforce a seam before trimming it off.
adora.lam (author)2015-04-17
Can you please tell me where I can buy the transparent film you used to transfer the pattern?
dedmo002 (author)2015-03-17
I, too, am having trouble following the boning instructions. This may be because I am unsure of how your edged your seams. It looks like you fold it inside out but I never see you make a mention of that. Overall though I do love the drafting portion of this tutorial and it has been widely helpful :)
IviA1 (author)2015-01-19
Great advice! Thanks
cimocimi1 (author)2014-08-18
Gracias por la info ... esta información me ha ayudado en la toma de bustier básico. Espero el otro Info también eh ....
parisusa (author)2013-09-17
This is great! I have never learned how to follow a store bought pattern but I can follow this! The bone channels are unclear to me but I can look it up. Thank you! Following you!
About This Instructable
433,565views
524favorites
License:
More by corsetry:How to make a LilyPad Arduino LED skirtSilk Top / T-Shirt (sew within one hour)How to make a feather corset
Add instructable to:
