Step 17Naming Pins
Type name in the command window and double click on the pin to remain. A small dialog box will appear with the current name. Change the name and click "Ok". Repeat 32 times.
By default the name on the pin and the symbol will show up in the device. This makes for a very cluttered look. Click on the "change" button and select "visable" from the drop down menu, and then select "Pin". Then click on every pin. It will not be obvious what you are doing but trust me the final design will be easier to use.
NAME P$1 PGND_1
...and so on; one pin per line.
A programmer's editor like UltraEdit or SciTE makes it easier to add the "P$" to the numbers. When you're done, save it as an ASCII text file with an .SCR extension and load it from Eagle's File menu. Easy peasy!
