How to Make a Designer Mirror Frame Using Rope
Introduction: How to Make a Designer Mirror Frame Using Rope
Dear makers,
Today in this instructable I will show you how to make a designer mirror frame using rope. Yes, no wood, no plastic, no metal, no glue etc. Just good old...rope :).
I had this idea since long, but I was busy making jewelries :).
As awesome (and may be complicated) as it looks, it is easier than you think :)... (The keyword is always ...easy :))
I had also previously made a mirror frame using pebbles, you might want to check it out:)
The inspiration behind the mirror is my paracord projects. I am still very knotty ;). If you have worked with paracord and not with rope , like I did. You will notice that rope work will required some muscle work ..ha ha. Don't worry, you don't have to play tug of war here.
Oh and this is totally a origianal idea of mine, so if you are reading this, you are among the special ones :D
PS: I am very happy to post this 50th instructable of mine. I like to thank everyone here for continuous supply of motivation and inspiration :)
Lets see how to make a designer mirror frame using rope.
Step 1: Things You Will Need to Make Designer Mirror Frame Using Rope
To make this mirror or exactly like this mirror, you will need
  1. A round mirror. Diameter of your choice. Mine is 11"
  2. A rope around 1/2" thick. I used natural fiber (I guess silk) rope, but you can use any rope so long as it is neatly braided.
To work on this mirror size using 1/2" thick rope, I used around 24 feet of rope. The best part of this design is you don't have to cut your rope initially to fit the measurements, you can just keep on tying and when you are done, you can choose to cut the rope to desired length.
The knot pattern that we will use is round brocade knot. the beauty of this knot is that it forms a nice hollow space inside, which allows any object like this mirror to fit in the gap securely.
Ready to get knotty?...lets start.
Step 2: Knotting the Rope
See images above and follow:
  1. Leave about 1 feet of rope.
  2. create a loop such that the right side of rope is below the loop intersection.
  3. Make another loop with right cord so that the pattern look like a M shape.
  4. Insert the loop on right into the loop you created in #2.
  5. Twist the inserted loop gently towards right. Carefully tighten the left loop to secure the right loop inside.Pull the right cord to make the loop slightly smaller. (See 3rd image in sequence.) This is important
  6. Keep repeating from 2-5 and measuring with mirror.
  7. Stop when you complete the round pattern and there is gap for at least 1 more knot.
You are almost done. In the next step, you will learn how to join the loose ends and secure the mirror.
Step 3: Securing the Mirror
  1. Insert the right end of cord inside the right loop, adjust the cord to make loop little smaller but not too tight.
  2. Pass through the right cord inside the left loop such that left cord is below it.
  3. Return the right cord back inside the right loop but from left side.
  4. Adjust both the loops carefully to make them firm.
  5. Pull right cord to bring the two ends together.Insert the mirror and adjust such that the mirror edges sit inside the tiny canal formed inside due to continuous knot pattern. This is the reason why this knot it suitable for wrapping objects.
  6. Pull both the cords to make the arrangement tight and also make sure the mirror is in place.
Once the mirror is secured properly, it is totally up to you to device the hanging mechanism. Here's what I did.
  1. I kept around a feet long rope on both sides.
  2. Leaving about a quarter feet from top, I tied both the ropes using some white paracord I had. I used simple or overhand knots a couple of times.
  3. I also left the rope ends open such that they form a nice pony tail.
That is all my dear friends. Hang your latest creation with pride.
I loved the way this mirror turned out, I hope you do too.
Thank you for your time to read this ible. Should you have questions or feedback, please do share in the comments below.
If you like it, please do share and please vote.
You are awesome
Stay tuned.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Nicely done, and such a famous and simple knot! Would that I had thought of it. Any idea how much rope you used?
    Thank you so much :). For an 11" diameter mirror, I used 1/2" thick rope of about 24 feet. Step 1 above has the details :)
    very nice :-)
    Hello what an awesome way to frame a mirror and something unique that's not around and mass sold. I was wondering if this would work for square mirrors as well ?
    Thank you so much for your kind words, although this knot naturally forms a round shape but it can be used on square mirrors when stretched & adjusted properly to fit :)
    Wow, It looks Stylish.. Detailed ibles.. Nice :)
    Happy 50th Instructable!! :D This is great, I love the knots pattern! Oh and as soon as I saw the photo on the homepage I thought the mirror was much smaller...I guess I had your paracord medallions still in mind...I'm starting to realize how big it actually is now! :)
    Thank you so much Linda :). You are right about the mirror medallion, actually this project was suppose to go live before that one but I was so moved by those little mirrors that I posted them with paracord and it proved to be a great practice too.
    I have always loved how you remember my old's just feels so good :)
