Thanks DarkMuskrat:
"Hey, this is pretty good for any guitarists.
And i'm pretty sure that part/tool is just called a "plastic cabinet handle"
you can buy them anywhere so maybe check at home depot or somewhere."
so if you ever see the words "weird unnamable tool" just remember, it's a plastic cabinet handle!
here's a super helpful tip from gmoon:
"I like your capo (+plussed) ...might I suggest you replace the screws with a threaded shaft (cut off the screw head), then use wing nuts to tighten / attach the wood piece?
Then you could take it off and tighten it without a screwdriver..."
and remember to rate my instructable! thanks.
Remove these ads by
Signing UpStep 1Gather Your Materials
1. an Unnamable tool, see picture one, and someone please tell me what it's called! (it should already have screws)
2. A ruler or some small piece of wood
3. plastic washers (if you want)
4. clamps (optional)
5. CD-Spindle foam cylinder
6. cutting tool (old knife or superlong dremel cutter tool)
7. Rubber sole from an old shoe
8. Electrical tape
9. Tea Candle and matches
Both foam padding and rubber strip can be thinner, making the design less "chunky". Great idea to use "shoe sole" rubber, because that's hardened for long-term use.
I'll refine this design by curving the wooden ends, painting the washers black, or inking them black with a marker. Spray the "cabinet handle" gold (and the screws) - I'll also try to put a slot in one end of the wood, so the capo can be easily taken off / or attached. (that might be tricky if the clearances aren't right).
Only real down side is you might dent guitar neck if it's over-tightened. Wouldn't use this on a vintage gib, initially!
Still, Good job on this!
