How to make a district 9 Weapon
 by msraynsford
Featured
It's halloween again so there is time to make something large and extravagant for no particular reason other than the fact that you want to. With this in mind I decided that I wanted to build the gun that Wickus carries around throughout the district 9 film. I also decided to use this as an opportunity to use the Isopon (Bondo?) I bought to make the prop slightly more substantial than my usual paper mache fayre.
Like most projects it's best to start with an image of what you're trying to acheive. A quick scan of the web found the two images included below, the first is from Weta directly and is in higher res and therefore shows more details. The second is clip from the film which has the gun in a colour I prefer and shows it in a slightly different angle, both will be useful.
I now have a growing collection of costumes and props from the numerous fancy dress parties I've been to. This gun is rather large and I don't like the idea of moving it from house to house as we bounce around so I have decided to ebay it. If you read these instructions and decide that you would like to own this gun now is your opportunity....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280416682647
This and all my other projects can now also be found on my own website at http://msraynsford.googlepages.com
Step 1: The materials
As I wanted to make something a bit more substantial than the paper mache I've used a wider range of base materials.
XPS foam, this is the pink loft insulation foam and is used to form the base of the gun.
Isopon P38 (The easy sand stuff), used to give a solid plastic coat to the weapon.
40mm plastic pipe, used as the core to the nobbly bits
8mm threaded rod (or similar solid bar) to connect the nobbles to the rest of the gun
Bottle caps, used to plug the pastic pipe
5mm dowel, details on the nobbles
Cardboard, used for details and tubes
Brown paper (any paper will do) used for the paper mache parts
PVA Glue, used as a protective cover to stop the solvents eating the foam
Hot glue, used to stick the foam parts together
Black and White acrylic paint. Many shades of grey to be made here, one of the joys of black and white weapons. Gun Metal coloured acrylic for highlights and weathering
Step 2: Naming conventions
So before I launch into several pages about sticking the nobly bit to the long bit and painting the whatnot I figured it might be quite useful to define some names for the parts. These may or may not be what the 'prawns' had in mind but this is my interpretation of it. Feel free to argue where your ideas differ but I'm not listening :P
The barrel, Stock and Handle are fairly standard gun parts so I'm on safe ground there.
The front of the gun has a stuck out bit which looks like the pilot flame for a flamethrower. I call this the spark generator (not to be confused with Sparc International mind you!)
The nobbly bit reminds me of the high voltage electricity stuff, so I call this the cascade tower.
The bottle on top of that I call a reservoir, conveniently placed to slowly drip stuff into the tower.
The bottom cylinder is below the gun so presumable injects stuff upwards, hence becomes the injector.
Finally the large cylinder on the back of the weapon reminds me of a power cell.
Step 3: Measuring up
Now to work out how big this thing is going to be. The photo of Wickers carrying the weapon gives us a starting point for scale. Do the classic artist thing of holding a pencil up to the image and marking with your thumb the length of his forearm. Compare this to other parts of the image and you will see that the stock and the barrel are pretty much the same length. Now measure the length of your own forearm and you've got a pretty good place to start.
To take this further you need to resort to some other method. I loaded the image into paint.net and drew a selection box around barrel of the gun. This told me it was 416 pixels long, the length of my forearm is 350mm long so therefore the image has a scale of 1 pixel to 0.8mm. By moving the selection box around the image I was able to measure virtually all the parts of the gun separately. I have included a quick doodle of my results and also a snapshot of my logbook containing more of my measurement details
Step 4: The main gun form
The main body of the weapon can be created by using 4 simple shapes of foam. Taking a sharp stanley knife to the foam (the extendable blade is useful to eventually cut through all 52mm of foam), cut along a straight edge in nice even strokes. Don't cut too deeply, just let the knife do the work, each time cutting a little deeper than before. This should give you nice flat surfaces to work with
The barrel is 90mm high and 400mm long. One end of the barrel is cut with a notch to make room for the injector. The main diagonal is 90mm high by 280mm long, cut both ends at a 45 degree angle. The main part of the stock is 52mm high (to make it a square section) and 400mm long, cut the front of the stock at a 45 degree angle. Finally cut a piece of foam 40mm wide by 100mm long. This will form the L shaped part of the stock (different to photos). Use Hot glue to stick the pieces together, make sure each join has a good covering of glue and is pressed well together. Run the hot glue around the edge of the join to fill any gaps and to make the seam stronger. (You don't want the gun to break along these joins)
Cut a small 30mm long section of 32mm wide plastic pipe is inserted into the front of the barrel. Press the pipe into the foam on the font of the barrel, then use a scalpel to cut a circle where the pipe will site. Now when you come to glue the pipe in place it will slide into the foam and hold much better. Carve the foam around the piper to provide a rounded shape for the barrel.
Finally add a bracket to hold the cascade tower, this should be 100mm along the top, 90mm high and 40mm wide. Glue this in place with more hot glue, reinforcing the seams as you go.
As you can see from my images I did this stage slightly differently. I added some details into the stock as I was cutting it but if I were to do this again I would be do it this way and then slowly build up the stock with more pieces as described. I also added the injector bracket but again this is probably better done at a later stage so it becomes easier to work in that gap.
Step 5: The Handle
The handle is one of the most complicated shapes on the weapon. This is made from pink foam which is quite carveable by hand. I split the shape into a further three parts, the handle, the trigger (easy) and the guard. I started to cut them out by hand and my skills deserted me so at this point I resorted to my CNC. This allowed me to carve the handle and the guard from the same piece of foam. The trigger was cut from the gap between the two (although with a bit more effort it could have been joined as well)
First thing was to create a pattern for my CNC to cut around. In my 3D modeling package I loaded the image as texture on a simple polygon. I scaled the polygon to the appropriate size and then started to use it to draw some splines. (Splines are special lines that my router will follow to cut out an object). The splines are converted to GCode through the program CamBam, and then run on my router with the program Mach 3. I'm sure if you have access to some kind of CAD machine this will already make sense to you, if you don't then you can come round and borrow mine (genuinely) or you're stuck doing it by hand.
Step 6: Adding shape to the barrel and stock
The barrel is starting to take the right shape now but it still needs a bit of work. To make the barrel wider you will need to start adding material to the barrel. Sheets of cardboard are cut to shape to provide nice straight edges, although this step could be done with more pink foam, cut and then sanded back to the desired shape.
To keep the structure strong (it is the area you hold the weapon after all) it is made up from several triangular prisms, these shapes are strong in all direction and easy to construct.
Cut a piece of card 64.5mm wide wide 400mm long (this dimension can be made up with several shorter pieces). Score the card along the width to create the sides of the prism, these should be 5mm, 25mm, 24.5mm and 5mm wide. Fold the card and glue along the first 5mm length. Fold the card into a prism shape and glue this edge to the other 5mm wide edge. This should form a triangular prism with a right angle.
Repeat this process to create a second prism for the other side of the barrel and for 2 more prisms with sides of 5mm, 15mm and 14mm. Next cut a larger piece of card, 400mm long and 154mm wide. Score this piece into widths of 15mm, 10mm, 25mm, 54 mm, 25mm, 10mm and 15mm. This will wrap around the prisms and the barrel to form the desired shape. Glue the prisms to the larger sheet. A picture speaks a thousand words so I've included a doodle of this all.
Finally cut a notch out of the card in the same shape as the injector notch, then glue the whole shape to the barrel. This provides the added bulk to the barrel.
With that done it's time to add some shape to the stock. This I have less photos of but it is fairly straight forward. Cut some 5mm thick stips of foam from the block, this thin sheet of foam will be flexible enough to provide a curve to the stock. The foam will be the same width as the stock so start by building up the edges of the stock. Then create 2 'sheets' of foam by glueing 2 pieces of foam, 160mm long along the long edge. Carve the circular detail into this sheet and then glue it to the side of the weapon. Cut around the stock to make the sheet exactly the right size.
Step 7: Isopon for strength
I wanted to make this item strong and sturdier than the paper mache stuff I usually make so I headed down to the local halfords to see what they had available. I found Isopon P38, which is an easy sanding body filler. It's a two part polyester filler that forms a solid plastic coating to the weapon.
Perform this stage in a well ventilated area, make sure you have all of your materials to hand. Once you mix this stuff together you want to get it onto the gun asap without having to find things.
Mix up a small amount of isopon based on the instructions provided with the tin. Smear it all over the weapon, I applied it to one straight section at a time, this way there should be no visible seems along the same face and any visible joins would be on the edges.
Once the Isopon has hardened you can begin sanding, use a fine sand paper and a sanding block to go over each of the surfaces. Once completed you will have a nice and smooth cover to the weapon which should be water proof and provides a great surface to paint on.
Step 8: The cascade tower
The cascade tower is formed around a length of 32mm diameter pipe. To affix this to the main body of the gun an M8 threaded rod was. Bottle caps fit snuggly into the center of this pipe The rod holds several caps together allowing them to be rest in the centre of the pipe. Another bottle cap is used to reinforce the cascade tower bracket and the threaded rod was secured into the foam using plenties of hot glue.
This was largely acheived through my well experienced use of paper mache. I honestly wanted to try something a little more complicated like casting the part and then making 6 replicas of the piece so they would all look the same. In the end I decided that I already have lots of glue and lots of paper so making the same part 6 times would cost me nothing but time, where as my efforts at casting would cost me money and may not work out. The end result is that not all the nobbles are identical but it's close enough.
The end of the cascade tower is made from balsa wood and attached to another bottle cap with a single bolt through the centre, this is hot glued into position at the end of the tube.
Step 9: The power cell
The power cell is made out of cardboard cylinders with pink foam end caps.
To form the basic cardboard shape find another object with roughly the right diameter (80mm), I used a plastic drinks bottle. Wrap the first a sheet of cardboard (A4) around the bottle and use some masking tape to hold it in place. Don't worry that the card doesn't wrap all the way around the bottle, the gap will be placed against the stock so it won't be visible. Once the first piece of card is stuck down you have something to glue onto. Smear a second sheet of card with a good covering of the  PVA and water mix and wrap it around the first. Repeat this until you have 4 layers of card on the bottle and the card starts to hold it's own shape.
At this stage you need to make a second cylinder a little larger than the first. Wrap the next layer of card around the previous cylinder but this time don't glue it, hold it in place with some more masking tape. Build up another 4 layers on top of this one and wait for it all to dry. Once dry you can take the tube off the bottle former and seperate the 2 layers. Cut the bottom layer to the desired length and the top layer 30mm shorter.
Once the layers are seperated you can begin to carve some detail into the top layer. Draw the desired shapes on a flat piece of paper and then cut them out. To make four arrow shapes of identical sizes, draw one shape and cut it out, trace round this shape for the next 3 shapes and then cut those out too. Wrap the paper around the cyclinder and trace through the holes onto the card. Using a scalpel, carefully cut the shapes out of the card, being careful not to slice through your fingers.
To make the power cell end caps, first draw some circles of the correct size into the foam using a compass. Roughly cut the foam out of the block as a square shape. Carefully cut down to the line using a stanley knife to make lots of straight cuts until you have an octogon with the circle inside it. The cut the corners of the octogon down to the line, repeating until you get a roughly round shape. Sand the foam into a smooth circle. At this stage, cut the flat spot on the caps so that it sits against the stock.
To taper the end caps draw a line around the caps, 10mm from the end for one and 30mm from the end for the other. Hold the stanley knife at the desired angle (roughly 45 degrees) and cut from the line down through the cap. Turn the cap around 90 degrees and cut again, repeat until 4 cuts have been made, then cut those corners off, repeat as before until the shape is roughly circular, then sand the suface smooth.
Step 10: The Reservoir
The reservoir is made in a very similar fashion to the power cell,
Make 4 card board sheets roughly 30mm wide and the same width as A4 is long. These will be used to wrap around the base former. My tube was constructed around a pot of curry spice found in the kitchen cupboard. Laminate these 4 layers of paper by gluing them all together. Then add another 2-3 layers over the top again. This time they should all form complete cylinders around the object. Once dry take the top cylinder off and carve the detail into it.
Make the end caps from pink foam in the same way as before but this time the bottom end cap should come to a point, this will give you something to secure it to the cascade tower with.
Take the extra noble you made for the cascade tower, you will use this to attach the reservoir to the cascade tower. Use hot glue to fix the reservior to the top noble, more paper mache is used to cover the join between the two. The extra detail is added using tobing held in with hot glue. Don't worry about being too neat with the hot glue, once dry you can paint this a silver colour to make it look like welding on the pipe.
Step 11: The injector
The injector starts life as the inner roll from some cling film (seran wrap?). This gives the base shape to work with.
Take an offcut of pink foam slightly wider than the roll, press the roll into the foam until it leaves an indent. Cut a circle out of the foam roughly in the centre of the indent. This should be easily wedgeable into the cardboard tube. Wedge and glue the foam into the end of the tube and then carve it into a rounded shape, sand it smooth.
To make the rings to go around the injector cut a 5mm slither of foam from the block. Foam this thin is flexible and ideal for the job. (You could carve this the same as the other circles but cutting the inside hole for the tube to fit into is a little harder). Wrap this foam tightly around the tub and cut it marginally longer than it needs to be. Slice the foam on both ends at a steep angle (image 3), this makes the join in the ring less obvious. Glue one end of the foam and wrap it around the tube as tight as possible, use masking tape to hold it in place. Make a second ring and wrap it around the first, this ring can be glued along the length of the foam to secure it to the first ring. Once the glue has dried you should be able to slip the rings off of the tube, this is important because the top ring of the injector has to be fitted while it is in the gap of the gun.
Paint the parts of the injector with some silver acrylic and black details and this part in then ready for assembly into the rest of the weapon.
Step 12: The spark generator
The spark starts life as a chunky Biro, in fact mine was more accurately a Disney Princess biro that I found in the local pound shop and cut up so that it could serve a better purpose.
Unscrew the pen and empty if of the contents. Springs and ink can be saved for future project. Using a hacksaw cut the end of the Biro off. In my box of spare parts I happened to have a rubber sleeve that was about the right size for this job. Cut a 200mm length of the 4mm silicon tube and attach these items together with a little bit of glue. If you don't have a tapered rubber sleeve like mine then you could use a length of heatshrink shrink it at one end only.
Cut a piece of card to hold the pen in place. The basic shape should be large enough to wrap around the pen and then hold the pen 100mm away from the gun. Cut several pieces of card in a similar shape. Hold the first piece into a rounded shape using masking tape and then glue the other pieces over this first one. Laminating the card like this allows the piece to hold it's rounded shape once it has dried.
The two sides of the card are held apart wth some basla wood cut to the right width. The second piece of balsa should extend beyond the curvature of the card to provide a flat base to glue the spark generator onto the body of the gun. To add extra strength to cardboard I fabricated an H shaped piece of card to sit between the two sides.
Paint the shape with some dark grey acrylic ready for assembly into the gun
Step 13: The details part1
There are a lot of details with this weapon, this is a briefly outline of each of the items built the pictures should provide most of the information required for construction.
The rectangles that run the length of the barrel are made from framing card. This thicker card material was cut into the appropraite shapes and then aligned to a base piece of card, when complete the whole row was glued to the side of the barrel.
The large grey panel on the side of the weapon was formed from a thin sheet of pink foam. Once cut to the right shape the corners were rounded with sanding paper, and then the edges were tapered to give it the right look. This is painted a grey colour and then stuck directly to the side of the weapon.
The cross was carved in an offcut of pink foam. The offcut was quite thick so this piece was cut in half and used on both sides of the gun. The bolts were made with smaller again with pink foam. The small circles were glued onto the square and then the end of a paintbrush used to put dimples in the top. Once painted they look like the heads of bolts. I would use this method to put bolts in all the other places of the weapon, if I were to do this again.
Step 14: The details part 2
The triangular detail on the side of the gun was made by cutting into a thin sheet of pink foam, the end of a pen was used to create a rounded impression for the larger circle. The foam was placed on a piece of card and then painted, later to be mounted on the side of the weapon.
The heatsink on the top of the weapon, near the power cell was another block of pink foam. The fins of the heatsink were made by folding a piece of card and gluing it along the edge of the block.
The heatsink for the side panel was made in a similar fashion, this time 5 of the fins were made longer than the others and angled to point in towards the centre of the circle. The semicircular heatsink was made from pink foam, the impressions were made with the edge of some pliers, edge ridge points towards the centre again. The box and the circle were made with funky foam, this allows an impression to be made in the foam which shows after painting. In hindsight the circle should also have an inner impression. The tubing detail was made by applying some hot glue direclty to the backing plate, this gives a solid half rounded look to the item. The whole plate was painted with a dark colour and the gun metal paint was used to dry brush over the top, giving it a metallic look.
The saw teeth on top of the barrel are made from balsa wood, (as the close up shows how rough they are it would perhaps be better to make them out of foam), the shape they sit on was made from cardboard with a foam center for solidity.
Step 15: Painting and Finishing
Once all the details are on the gun you can give it it's final paint coating.
This is now ready to form part the centre piece of your Wickers costume.
I'm sure there are many details left out of this instructable, ask me and I'll add them in. I'm also in the process of improving all the steps but these things take time and I wanted to get the weapon and the instructable released before halloween.
Thanks for you patience.
1-40 of 43Next »
fostersfriend says: Jul 20, 2012. 9:08 PM
but u messed up on the cascade tower its one short dis is fake aghhhhhh!!!!!!!!!
just kidding im amazed you pulled it off at all this is quite the prop :)
CaptPikel says: Oct 31, 2009. 12:59 PM
I was wanting to make something like one of the weapons from that movie. Can't say I was a big fan of the movie itself but the weapons were pretty cool. I want to make one that actually shoots something though. Still a while off. Very good instructable though.
Pazzerz in reply to CaptPikelNov 2, 2009. 3:42 AM
Go to spudfiles and get a good idea of how to build something that shoots.  Once you get the idea, try to incorporate it inside the shell of your 'favorite' movie/game weapon.  The site should help you speed up your project.
fostersfriend in reply to PazzerzJul 14, 2012. 7:50 AM
im just gonna put a low power coilgun in mine
Victor Lam says: Dec 30, 2009. 8:23 AM
fostersfriend in reply to Victor LamJul 14, 2012. 7:48 AM
that is the regular color scheme from the movie
meat sack says: Apr 6, 2010. 3:27 PM
i like that movie
RSV26 in reply to meat sackFeb 8, 2012. 8:17 AM
me toooooo
3VIL G3NIUS says: Jun 23, 2010. 4:22 AM
How comfortable is that pistol grip? It seems to have some pretty random angles in it (clearly designed for 3 digit prawn hands) but what does it feel like for a human?
RSV26 in reply to 3VIL G3NIUSFeb 8, 2012. 8:16 AM
whatch the movie and see
msraynsford (author) in reply to 3VIL G3NIUSAug 3, 2010. 4:27 AM
weirdly comfortable. It's definitely chunky in the hand but it kinda works especially as the rest of the gun is so massive it needs 2 hands anyway
fostersfriend in reply to msraynsfordJul 20, 2012. 9:15 PM
yes im quite suprised how it feels i decide to use mdf for the handle on mine but it feels like you are holding two 2x4s its really awkyard anyway i kinda want to make the whole gun from mdf cause it would feel right but then again it would be a pain to lug
suks that that guy killed a bunch of people ate the batman movie i wanted to take my d9 gun to the movie premiere for the sequel to district 9 i need a petition to get neill bloomkamp to get off his couch and make another one
luka1184 in reply to msraynsfordOct 27, 2010. 1:38 PM
I would buy more accurate newer updated version, along orker D-9 wespons. You Said you had a great time making this kind of stuff, so dont you wanna team up with me become friends and design props and replicas slap, with me ;D i have plans and ideas for D-9 stuff and we need bigger and cooler version(s) :D
3VIL G3NIUS in reply to msraynsfordAug 3, 2010. 5:11 AM
cool, looks like I may use it for a bbmg then!
Rich_D says: Mar 30, 2011. 8:51 AM
Truly amazing replica! I'd like to try something similar, but need to know if XPS foam and the Isopon P38 are available in New York City, or at least what the American counterparts would be. I'm tired of getting blank stares from store clerks when I say XPS foam or Isopon P38!
lil larry says: Mar 17, 2011. 7:17 PM
Wow! Nice instruable! District 9 WAS an awesome movie. Now I feel awesome doing this! 5.0*
j44 says: Nov 14, 2010. 9:27 AM
Great instructable!
For coating the foam (Step 7)
I tried Isopon P38 but it dissolved the foam I was using, in the end I found a no more nails type of filler/glue worked well.
partypope says: Nov 2, 2010. 1:56 PM
I am in the process of making this and i find the lack of measurements... intimidating. The Measurements on the diagonal had me confused for a while, and i decided just to completely wing that part.
And i have no idea the width of the handle.
Anyhow! Besides that GREAT instructable. It looks fantastic. Hoping mine will look just as awesome!
BkrevWlevqe says: Aug 3, 2010. 3:52 AM
Hey ford, how much did you get for this awesome D-9 weapon? It deserves 300$, nothing less than that!
msraynsford (author) in reply to BkrevWlevqeAug 3, 2010. 4:25 AM
It's very subjective, would you pay $300 for it right now? In the end it went for £30 but I guess I had fun making it and now it's happily sat in someones collection. If you wanted your own though I'd happily make you one for $300.
BkrevWlevqe in reply to msraynsfordAug 3, 2010. 9:17 AM
No thanks man, I'm a pauper :-)
robertlim says: Jul 30, 2010. 4:55 AM
it looks cool, but it's not
skidude28 says: Dec 15, 2009. 6:02 PM
Figure out how to make the mech :D
WhiteTigerTails in reply to skidude28Jul 7, 2010. 9:06 PM
AGREED! Though, without the painful neural connection thing...
smallman98 says: Apr 18, 2010. 4:41 AM
if you use pink foam board how sturdy is the gun?
Dilong_paradoxus says: Oct 30, 2009. 9:44 PM
 Nice job! Can't really tell the difference between your picture and the movie picture, except yours looks a little less weathered...
(puts on christmas list).
msraynsford (author) in reply to Dilong_paradoxusNov 5, 2009. 1:21 AM
Yeah need to brush up on my weathering techniques, I think I've got the metal stuff down but need to work on general wear and tear
Dilong_paradoxus in reply to msraynsfordNov 5, 2009. 6:54 AM
It looks cool anyways...more new...
Notbob says: Oct 30, 2009. 3:23 PM
This is amazing, i love how good this looks. Any chance you will make this one?
msraynsford (author) in reply to NotbobOct 30, 2009. 3:56 PM
I'm afraid there is no chance of me randomly making it on my own, but if somebody was willing to fund it I'd be more than happy to devote some of my spare time to it.
If I remember rightly, doesn't that one also have some really cool purply glow section in the front of it? Would make for a very cool prop.
Notbob in reply to msraynsfordNov 4, 2009. 11:37 AM
This one, seen here firing, had an orange effect, almost like kind of fire.
general-Insano in reply to NotbobNov 4, 2009. 1:07 PM
If you felt like it you could go in this direction   http://www.instructables.com/id/How-to-make-an-Iron-Man-Arc-Reactor/   to create the orange glow at the muzzle of the gun and maybe if you are good at arduino you could also do an alternating flashing pattern for each led
Notbob in reply to general-InsanoNov 4, 2009. 3:06 PM
Good idea, I was thinking along the lines of frosted plastic, with orange LED's lighting it up (think like in the portal gun).
msraynsford (author) in reply to NotbobNov 5, 2009. 1:19 AM
I can thoroughly recommend that instructable :)
The polymorph is pretty good for diffusing the colour of the LED's, arduino's are pretty good for beginners, but something like a PIC12 would be a lot smaller with less components and easily capable of a small job like that.
cowscankill says: Nov 4, 2009. 1:22 PM
One of the best models ever. Really great use of the foam! I need to try making some more prop guns soon... but like working ones. Better ones than I have posted by like 200%.
Anyone have suggestions for me?
JamesRPatrick says: Nov 3, 2009. 6:24 PM
Awesome job. I love the Instructables color scheme that the Prawns use.
Tape-structable says: Oct 31, 2009. 12:05 PM
Wow! That looks just amazing!
DainiusGB says: Oct 31, 2009. 2:30 AM
 Wow that is really cool! Good job!
graphak says: Oct 30, 2009. 11:00 PM
 This is pure awesome!  I'm hoping people will remember district 9 next year so I can have it done in time, along with a prawn suit lol
ItsTheHobbs says: Oct 30, 2009. 6:37 PM
 This is EPIC. I need to see that movie, looks pretty cool.
1-40 of 43Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
