Step 5The Handle
First thing was to create a pattern for my CNC to cut around. In my 3D modeling package I loaded the image as texture on a simple polygon. I scaled the polygon to the appropriate size and then started to use it to draw some splines. (Splines are special lines that my router will follow to cut out an object). The splines are converted to GCode through the program CamBam, and then run on my router with the program Mach 3. I'm sure if you have access to some kind of CAD machine this will already make sense to you, if you don't then you can come round and borrow mine (genuinely) or you're stuck doing it by hand.
Add Comment
