3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a double bladed staff sword
Step 1Assemble items
Assemble items
You will need:
1 1-1/8 inch x 48inch wooden dowel: $3
2 22inch machetes: $46
Duct-tape:$3
25 comments
Dec 10, 2010. 9:12 PMxw239 says:
Where did u get the machetes????!!!! I've been needing a realistic (real) machete for a Jason Voorhees costume. That sure as hell looks like Home Depot. Plz tell me it is :)
Mar 19, 2012. 9:36 AMbendog38 says:
That IS Home Depot. Pretty sure.
Apr 17, 2011. 10:35 AMFunky Mcgroovy says:
In Minnesota there is a place called Harbor Freight. I know they have them there, and they are pretty cheap... $5 to $10.
Apr 17, 2011. 10:37 AMFunky Mcgroovy says:
This might help too
http://www.harborfreight.com/18-inch-machete-with-nylon-sheath-94154.html
Dec 8, 2010. 2:14 AMskimmo says:
good old bunnings
Mar 7, 2010. 9:33 AMmannyisdead says:
You should remove the grips, put the machete ends inside a tube, weld and build a new grip.
Oct 24, 2010. 4:41 PMvtheawesome says:
and then make the blades not quite as broad
Apr 15, 2010. 1:36 AMvalkiraun says:
 Disappointing. I thought I would be able to construct a bisectioning glaive (Much similar to that of 'gabranth' from Final fantasy 12) using this instructable, yet, it only tells me the obvoius parts.
Mar 28, 2010. 12:45 PMpogoman12345 says:
i had a thought of making something like this but never really got around to it
Nov 26, 2009. 9:22 PMtotjup2 says:
yes i agree that duct tape is a bad idea. i recomend u take the handles off the machetes the cut a notch in the ends of the dowels. drill two holes in the machete blades and on both sides of the dowel. then u can use a few bolts to hold the  machete blades in place.
note: if you do not wish to ruin those more expensive mechetes, you can get one for like ten bucks at walmart.
Aug 13, 2009. 11:41 AMkleinjahr says:
Tape,Duck!! If you start swinging that about, likely the blades will come out, certain if you hit anything with any force. Suggestion for improvements: 1: open mortise each end with holes to match the rivet holes in the tangs 2: reinforce the ends with something like copper pipe or wire binding/whipping If you want something more like a real naginata,use a six foot dowel perhaps with a counterweight at the butt. A bit of lead or a pipefitting would likely do.
Jun 12, 2009. 5:59 AMskimmo says:
would, it be easier just to use the machetes as... machetes?
Jun 20, 2009. 8:45 AMknifepyro says:
yes this is dum
Jun 20, 2009. 8:44 AMknifepyro says:
this is dum all u did was tape knifes to a stick
Jun 19, 2009. 11:42 PMabadfart says:
what if you striped off the handle cut a slit in each end of a pipe and weld them in
Jun 12, 2009. 6:33 AMGage987 says:
why don't you just strip the machete handels down and cut appropriate holes for them and turbo super mighty jesus glue them in then wrap in electric tape for looks
Jun 5, 2009. 6:34 PMvolquete says:
you're gonna be twirling that around and the duct tapes gonna snap and your friends gonna have a machete in his eye
Jun 3, 2009. 11:47 PMlmuli3 says:
yep it will snap then next thing you know you have a machete stuck in your foot
May 23, 2009. 5:22 PMRotten194 says:
Because we REALLY needed instructions to do that >_>.
May 7, 2009. 12:23 PMjosh_pogo says:
using duck taps a bad idea
Apr 28, 2009. 8:11 PMcorey_caffeine says:
dont use duct tape for this remove the hand grip, split the the dowel in half along its length and figure it out from there (hint: epoxy is key and you'll need veneer to fill the gap)
Apr 13, 2009. 2:22 PMjosefu0 says:
cool but boring get more information
Apr 12, 2009. 8:09 AMdisturbedforever says:
cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pigeon853
