3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a double chamber water-bottle cork cannon
I made this a while back, and thought i'd let you know how to make it, it's pretty powerfull!!!
http://www.instructables.com/files/deriv/F80/B86T/FQMXF8UR/F80B86TFQMXF8UR.MEDIUM.jpg
Step 1How to make it...
How to make it...
  • last photo ←
Ok so you will need the following:
-A cork
-1.5 litre water bottle
-0.5 litre water bottle
-A valve that you can open and close whenever you like(go to the drug shop and ask i'm sure youl find it, ask for a small one.
-bicycle tube
-thin tube(motorbike fuel line tubes)
-scizors
-A cardboard tube( i used plastic, because i had it :P)
start by removing the valve(Not the drug shop one) from the bike tube
http://www.instructables.com/files/deriv/F2T/AOYG/FQMXF8UP/F2TAOYGFQMXF8UP.MEDIUM.jpg
make a hole on the bottom of the big bottle(1.5 litre)
http://www.instructables.com/files/deriv/FW9/7PWA/FQMXEPJR/FW97PWAFQMXEPJR.MEDIUM.jpg
and insert the bike valve in it
http://www.instructables.com/files/deriv/F6W/NERH/FQJZO2CY/F6WNERHFQJZO2CY.MEDIUM.jpg
grab the Tap from the big bottle(1.5 litre) and make a hole in it
http://www.instructables.com/files/deriv/FZ5/D5B5/FQJZO2CZ/FZ5D5B5FQJZO2CZ.MEDIUM.jpg
the insert half of the tube from the motorbike fuel line in it
http://www.instructables.com/files/deriv/FUM/GAUU/FQMXEPJV/FUMGAUUFQMXEPJV.MEDIUM.jpg
Put the valve from the drug shop on the other end of the tube.
http://www.instructables.com/files/deriv/FX0/FCH8/FQJZO2D7/FX0FCH8FQJZO2D7.MEDIUM.jpg
Put another tube on the other side of the valve from drug shop
http://www.instructables.com/files/deriv/F0Y/MB1S/FQMXBIH6/F0YMB1SFQMXBIH6.MEDIUM.jpg
make a hole at the bottom of small bottle(0.5 litre) and insert the tube there, and put the Tap of the big bottle on it(with the tube in it)
http://www.instructables.com/files/deriv/FX4/QHI0/FQMXEPJW/FX4QHI0FQMXEPJW.MEDIUM.jpg
Put the cork in the small bottle
http://www.instructables.com/files/deriv/FYJ/SK8B/FQMXEPJX/FYJSK8BFQMXEPJX.MEDIUM.jpg
And the carboard pipe, make sure it doesnt touch the cork!!!
http://www.instructables.com/files/deriv/FTC/V48V/FQMXEPK1/FTCV48VFQMXEPK1.MEDIUM.jpg
Get a bike pump, and start pumping the schraeder valve(i usually put 4 bar pressure, that gives me 200 feet of range with the cork ), oh and close the drug shop valve!!!
http://www.instructables.com/files/deriv/FLR/83UV/FQMXF8UQ/FLR83UVFQMXF8UQ.MEDIUM.jpg
You can attach the small bottle on top of the big bottle with a thick rubber band(if you want)
And it should look something like this
Now after it has 4 bar pressure, point at your target, and open the drug shop valve :)
WARNING: DO NOT POINT AT PEOPLE OR ANIMALS!!!
BEWARE, IT HAS A KICKBACK, AND SMALLER CHILDREN MIGHT BE AFECTED BY IT!!!
oh and try not to loose the cork...
And for night fun, you know those fishing chemichal light tubes?, make a hole on the cork and stick one there, it reminds me of plasma guns :)
Ok so be safe, and have fun!!! I fyou make another version of this let me know!
1 comment
Feb 2, 2009. 12:11 PMadmin says:
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:amando96
I will try my best to provide cheap and easy intructables!
