Introduction: How to Make a Drawknife
to make a bow with
Step 1: Materials
for this you will need;
metal, 1/8 in thick, 1 to 2 inches wide and 12 to 14 in long
2 metal 1/8 in thick, 1/4 to 1/2 in wide and 6 to 8 in long
2 wood dowels 1 1/4 to 2 in diameter and about ten inches long (i used a sapling I cut down)
4 bolts
tools;
metal grinder
arc welder
table saw
drill
4 bolts
tools;
metal grinder
arc welder
table saw
drill
Step 2: Grind
grind a blade on the long piece (a blade that is flat on one side)
Step 3: Weld
weld the handles on the blade
Step 4: Finish It
cut a slot in the wood (about an inch in)
slide the metal handles in
drill 4 holes through the wood and themetal (the holes should be the size of the bolts)
screw the bolts in the holes
