3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a eyepiece for telescope
Here are the instructions to make a eyepiece with recycled parts, is easy and cheap to make and gives good quality images. this can be useful to people given courses on astronomy specially those where you make your own telescope.
Step 1Get the parts
Get the parts
The first things is to get the lens from an old cd-rom or dvd, you will remove the lens, use a non working unit.
I use one from a dvd-rom, the lens was mounted on a square plastic this made easier to handle the piece, be careful, not no damage or scratch the glass
The cd-rom and dvd-rom are similar but they have different focus distance, keep this on mind, you can make two if you can dismantle one of each.
The lens can be mounted on a tube the size of the telescope barrel, searching for parts, i found one that i liked because the size was right, and need little work, the plastic bottle for35 mm film
The other main part is a small metal plate,
You will need 3 little fasteners and 3 little plastic washers.
5 comments
Nov 23, 2010. 11:48 PMwareneutron says:
i have not learned
Aug 5, 2009. 10:38 AMlowercase says:
Amazing!!!!!! What focal length does this tiny lens has? It's always great to have a cheap eyepiece.
Aug 3, 2009. 10:40 PMLftndbt says:
WoW!! That's a small / high powered magnyfication. It must be hard to view through. I'll try this out. Thanks
Aug 3, 2009. 9:42 AMrimar2000 says:
What a good idea to use that tiny lens!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:hvegar
Good to improve, not so good to create, or being creative
