Step 11THE FAST BLINKING LED BIKE LIGHT IS FINISHED
3 Simple Ways to
Share What You Make
Other ways to share:
70,625
views
Related: electronic, electronics, LED, bike, light, red, battery, science, bikelight, lamp
Comments: 179
Rating: 4.85
© 2012 Instructables
All Steps Viewing
and seriously $1 per led... i buy 20 at that price.. if 18 of them die ive still saved money!
Ive used quite literally 1000's over the years
I started when ebay led's were 70c each
I just wanted to let you guys know, that way you can buy more for less.
If you are using my circuits, the resistor values are the same...
I think you have an Instructables just for the project that you mentioned.
i m thinking to make a big project after this in that project im thinking to glow my name first and when led showing my name get off at same time my surname appear like in adds on malls, multiplex etc.. i want a electronic name plate in front of my house which will be a attraction to people.
so i want to ask some question
1. how shoud i glow large no of leds about 100 leds, 9 v supply is sufficient in simple words my question is how to calculate amount of power required to glow large number of leds
2. how should i know or how u know the value of resister and capacitors
3. connetion diagram so that i connect leds for my name and for my surname seperately
4. 555 timer work in this ciruit or should we have to use different ic
sir i want to build my basic so that i can make different different circuit for diffferent purpose
i think u make a reply as soon as posible
I am younger than you so you don't have to call me sir! :D
You have an ambisiuos project and you will probably need someone who knows how to solder and some basics with electronic....
Well lets start with the simplest question:
2. Resistors have colored ring on them (4 or 5) and that's how you determen their resistance... You can find these kinds of calculator on the net. Just google resistor calculator.... As a mater of fact, here is one:
http://www.dannyg.com/examples/res2/resistor.htm
And for the capacitors, usually their value is written on them.
4. I think that the 555 time wont work for this.... Google the 555 timer and read up on it....the time between blink, the on/off time is determened buy the resistors and capacitor....Maybe the easiest way would be to use a Microcontroller like and Arduino! You could maybe use 556 IC whitch is like 2 555 ICs in one! But I am not really sure.... As for your question, could you make something like this with a 555 timer, I would say NO.
3.As I sad I don't know any diagram, schematic, or as you say connection diagram that will do what you want....
1. Well, depends on how you wire them, parallel or in series.... In this Instructables I wired mine in parallel.... There is not much to it but there is difference! I suggest that you look at this instructables (http://www.instructables.com/id/LEDs-for-Beginners/ ) I hope it helps you!
Feel free to ask me if you have any more questions!
Stanislav
