3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a fast blinking LED bike light
Step 7The Electronic
The Electronic
OK. First I will give you the schematic, electronic plan, and in step 8 i will explain it.
18 comments
Jul 4, 2011. 1:44 AMstexmetalac07 says:
E brate koliko bi max dioda mogao da povezem na 9v na istoj shemi?
Sep 20, 2010. 9:56 AMcrashcup says:
Which components affect the rate of blinking? Could this be made to blink maybe 5-6 times per second?
Oct 29, 2010. 12:37 PMcreator22 says:
if you use a .47uf cap(which is what i used) yuor led(s) will blink faster than 22uf cap BUT be careful not to use to low a cap that it will looke like a normal light cuz it blinks so fast also any lower then a 4uf cap the led will get dimer
Oct 2, 2010. 7:48 AMmiked123 says:
It depends on the resistors and capacitors on the 555 timer. Check out http://www.doctronics.co.uk/555.htm or http://www.scribd.com/doc/38590997/Make-Intro-to-Breadboard-Electronics-551
Aug 15, 2010. 6:25 PMnoapparentfunction says:
Where does the 330-ohm resistor go in this circuit?
Jun 30, 2009. 6:58 AMtechmonster says:
in the schematic did you mean to say 108 k ohm
Jun 6, 2010. 2:52 PMjmsaltzman says:
Looks like just "180 ohms" in the schematic, though you do indicate that it's 180K (not 180) elsewhere.
May 15, 2010. 11:30 AMsridh says:
Hi
Can any one tell me how to draw these circuit   any specific Software .
Feb 10, 2009. 2:30 AMSrinu says:
Hi, I have a doubt. Am working on something for which i don't need blinking lights but need lights that gradually become dimmer and then brighter. Can someone tell me what to do?
Dec 31, 2009. 5:28 PMjbw825 says:
You would need to use an inductor and a 555 timer to do this. You would need to make the frequency of the timer slow enough so it would dim and grow brighter at the proper rate.
Feb 12, 2009. 3:18 PMclark says:
potentiometer* ...sorry, it just bugs me when things aren't spelled right haha
Feb 13, 2009. 8:53 AMSrinu says:
hey thanks for answering the query but what i want is the led to automatically glow brighter and dimmer after switching it on. any suggestions?
Dec 6, 2009. 10:02 PMgman2000watts says:
I've heard that if you wire enough capacitors, the leds will dim when switched off. Not sure about dimming when switched on.
Sep 10, 2009. 2:58 PMWin7Maniac says:
Definitely Arduino. It's cheap, and if you use it with a digital pot, it should work great.
Sep 25, 2009. 4:48 PMWin7Maniac says:
You'd definitely want to use the Arduino with a digital potentiometer such as the AD5220. With this IC, you can send a pulse command to the IC, and it will change. In PBasic, used for Parallax microcontrollers, this command is the "pulseout" command. If you "pulseout 30", you set the pot to 30 "notches"; I think it has 250 both ways or something like that.
Jul 15, 2009. 8:32 PMboydtoamuse says:
Won't all the LEDs pull too much current through the 555, burning it up eventually? I mean, little LEDs pull 20 milliamps and 555 timers are rated at 5-10 milliamps as a maximum rating. Have you found that your circuits burn out or anything?
Dec 23, 2008. 3:30 PMlucas_br says:
hello , I'm planing to use your Instructables as a base for another project how can I adapt it for a 12V power supply? (bike dynamo)
Jan 30, 2009. 9:49 PMDYLEGO says:
About the 180 K Ohm resistors, is it okay if they are normal tan 4 band resistors? They are 180 K ohms, just not blue...
Jan 31, 2009. 9:14 AMDYLEGO says:
Is it okay if I use one 3vLED, 100Kohm resistors, and .22 uf cap? That should hive it 1 blink per second, right? I just want to know if I can use one.
Jan 31, 2009. 3:58 PMDYLEGO says:
What if my capacitor is a polyester film(green boxy capacitor) and .1 uF? The closest electrolytic cap at Radio Shack was 2.2 uF and was non-polarized, so I got the polyester film ones. The guy said there should be no difference, but it still doesn't work.
Feb 1, 2009. 8:35 AMDYLEGO says:
I'll have yo get one online then, RadioShack doesn't have .22uF... Also the polyester film one was nonpolarized.
Jan 31, 2009. 2:26 PMDYLEGO says:
Three volts should be fine, 9v comes out, hits 300 ohm resistor, makes 3v. Should be good, don't know why I even asked if I knew the answer...
Feb 1, 2009. 8:43 AMDYLEGO says:
Which comment are you referring to?
Jan 1, 2009. 4:26 PMjoao.torres says:
use a transistor to amplify swich a secundary circuit
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:comodore
stanislav.drca@yahoo.co.uk stanislav.drca@gmail.com ______________________ One of my favorite inventors, and one of the most brilinat minds that ever walked the Earth is Nikola Tesla. Here are some T...
more »
