Step 2Traditional tepee fire
iImage Information
You're going to want to start by gathering a fire starter, such as dry grass, cattails, or pocket lint. NEVER use paper or dry leaves in a fire, they the hot ash will rise out of the fire and can start a forest fire. Now you can gather your firewood to start get kindling, which is branches that are no larger in thickness then your pinky finger, then collect tinder which are branches no thicker then 1 1/2 inches in diameter, lastly gather your fuel which are big logs. Once you have a large wood pile you can start building you're tepee, start by making sure you have a clearly marked fire ring, this is very simple to do just clear out leaves and other flammable objects and make sure your fire ring is clearly marked by raised ground or stones.
Place your fire starter in the middle of the ring Stick a sick into the ground and lean others around it and the fire starter once you have built the tepee with kindiling and tinder keep adding tinder to the fire until you have a nice bed of coals and then you can add fuel.
** Make sure all your wood is dry. h
