3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a flamethrower out of a Axe can
This instructable will show you how I made a flamethower for very cheap and it only took me about 5 minutes to make! Warning: I'm not held responsoble for property damage or personal injuries caused by trying to make this!
Step 1Materials you'll need
Materials you\
Here is a list of the materials that I used. All of them I got from my house.
1. you'll need 1 Axe can
2. 1 Zippo lighter or any other lighter that will stay light by it's self
3. 2 screws that are fairly long, I used 2 torx screws out of my old xbox that didn't work anymore
4. 2 neft darts with the tips taken off or any other foam type thing
5. 1 rubber band
6. one more thing you'll need that's not in the picture is a knife of anything that can poke a hole
27 comments
Nov 3, 2011. 10:20 PMkgraebner says:
lol i use axe and a lighter to take out spiders and such :P mofos can see shoes comin but with this thing its like. whats tha-- AHHHHHH... then they are no more :3 jus make sure the flame doesnt reach the bottle and blow your face off :D
Aug 13, 2009. 6:09 PMCruncher123 says:
kiteman just said it won't blow up...whew makes me want to make this again. Can I use any flammable spray like bug spray or something?
Sep 1, 2010. 7:03 AMSly-Delvecchio says:
Get something likke Isopropyl Alcohol (or similar). Put it in a misting bottle (and strong, non leaking one). Spray onto flame. The result is a short burst of very hot flame. I use it to take out wasps/flies, and it works first time every time.
Aug 15, 2009. 2:56 PMHardCoreHacker says:
yes but i wouldnt recommend most of those. The reason I say is because the spout goes straight up on many bottles. As long as the spout is horizontal it would be fine
Jul 3, 2010. 2:38 PMmettaurlover says:
I did something like this with a small aerosol can of axe, about a foot of thick wire and a birthday candle. You can change the can this way.
May 20, 2009. 4:05 AMliquidrive says:
VERY IMPORTANT question: I have a similar design, spray + lighter, only it is much smaller, maneuverable, and easier to operate and carry in a pocket. My concern however is safety. Can anyone tell me what are the chances of that spray blowing up in the user's hand ? My flame is somewhat closer than yours, like half an inch away from the nozzle exit, but does not get the plastic hot at any time. you could simplify the design a lot by just putting a spacer between the spray and lighter, and then duct taping them together, with the spacer making sure the flame won't burn the plastic. My design uses 2 jet lighters, with buttins facing forward so they can be operated by index finger, and the jet flame does not move with wind. One of the 2 lighters always fires, making sure it's ready when you need it, like dogs and bears attacking you and all that :) So please reply if you know about the safety issue. Thanks :)
Nov 27, 2009. 5:03 PMGnomeMaster says:
yes but another thing that can happen is the fire to decide to go backwords to the inside of the can blowing it up from the inside
May 3, 2010. 8:16 PMstruckbyanarrow says:
nope, not a good fuel to air ratio for ignition inside of the can
May 4, 2010. 9:16 AMGnomeMaster says:
actully I've had a can of tag a can of aerosal hairspray and a can of spray paint blow up on me so dont go saying that it cant happen
May 5, 2010. 5:45 PMstruckbyanarrow says:
explode with this instructable? i think not.  exploding from other reasons not including spraying it through a flame im sure, you can drop one and they explode under certain conditions
May 6, 2010. 9:27 AMGnomeMaster says:
actully it was from holding a bic lighter infront and spraying a camp fire with it cuase it wasnt lighting
Dec 20, 2009. 7:41 PMdvnkmmy says:
he is right. i have a friend who is in high school. someone was smoking in the restroom. he was using some axe to hide the smell. it got a little close to the cig and the can blew up in his hand. he had to go to the hospital. is that going to happen? if a cig can blow up a can im sure a lighter can. it is just safety im worried about
Sep 1, 2010. 7:01 AMSly-Delvecchio says:
Bullshit. The can cannot explode in your hand by being exposed to a flame, and the flame cannot go back into the can. The can is high pressure and outside the can is low pressure... it's not possible for the flame to go "in" the can, and even if it did then nothing would happen because there's no Oxygen in the can.
May 3, 2010. 8:17 PMstruckbyanarrow says:
cigarette? that cant ignite aerosols.
Aug 26, 2009. 11:19 AMhobzez says:
how long can u spray it? is it possible u can keep spraying without the fire possibly getting into the can?
Aug 26, 2009. 9:51 PMprogramedfiles says:
the fire wont go into the can because of the compressed air and the pressure inside the can because of the compressed air and the pressure it is always trying to push the contents out
Aug 28, 2009. 4:33 AMhobzez says:
k thanks, cuz i just needed to know that cuz my friends are paranoid of it exploding in their hands
Apr 29, 2009. 11:26 PMyourmom13 says:
hav u actualy tried firing this? i dont want to get 3rd degree burns... i wud like 2 c a pic of u trying...
Apr 30, 2009. 9:00 PMyourmom13 says:
o oops i didnt realize... srry. thnx for th instructions!
Apr 27, 2009. 9:19 AMstephenniall says:
Lol i have done this but like a simpler idea I just got a old zippo wick i had Drilled a hole in the lid Glued the wick to it held it infornt of the valve thing and Let the wick on fire !! the same but snmaller lol
Apr 20, 2009. 3:49 AMjakee117 says:
a step up from the stupidity of other flamethrowers, this actually took some thought...I like it
Apr 19, 2009. 1:22 PMlemonie says:
For something that sounds moronic at face value this is actually quite a good build. Kiteman is right about the melting but the Zippo allows you the short bursts so you are able to avoid it.
(I like it)
L
Apr 19, 2009. 11:37 AMKiteman says:
There is a myth that flamethrowers like this can explode.
What is a hazard is melting - keep the flame going too long, and the plastic nozzle can catch fire or melt, and the pressure in the can then pushes the valve out, releasing the can contents much more quickly into the already-burning gas.
That will cause a fireball, which is what people mistake for an explosion.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Double E
There's not much to say about me but I like to mess with fire so i'm a pyromaniac and I like to do stupid things that I usally get into trouble for
