http://ruckman.net/archives.htm#FEATURED
and submitted by William Ruckman of http://ruckman.net
The first thing I would like to discuss is a little history, theory, and uses for fractal antennas.
Fractal antennas are a recent discovery. First discovered back in 1988 by Nathan Cohen and later published and patented in 1995. A fractal antenna has a few unique attributes as seen in this definition from Wikipedia:
"A fractal antenna is an antenna that uses a fractal, self-similar design to maximize the length, or increase the perimeter (on inside sections or the outer structure), of material that can receive or transmit electromagnetic signals within a given total surface area or volume."
What exactly does that mean? Well, you need to know what a fractal is. Also from Wikipedia:
"A fractal is generally a rough or fragmented geometric shape that can be split into parts, each of which is (at least approximately) a reduced-size copy of the whole,a property called self-similarity."
So basically, a fractal is a geometric shape that repeats and appears over and over no matter how far out or how far in you zoom magnification.
Source: Wikipedia and http://patimg2.uspto.gov/.piw?PageNum=6&docid=US007088965 Patent number: 7088965]
Fractal antennas have been found to be approximately 20% more efficient than normal antennas. Which could be useful. Especially if you want to make your own TV antenna to pick up over the air digital or high definition video, increase your cellular range, wifi range, FM or AM radio reception, and so on. Most cell phones already have built in fractal antennas. If you noticed in the past few years that cell phones no longer have antennas on the outside. That is because they have a internal fractal antenna etched on a circuit board which allows them to get better reception and pick up more frequencies such as bluetooth, cellular, and WIFI all from one antenna at the same time!
Wikipedia info:
"A fractal antenna's response differs markedly from traditional antenna designs, in that it is capable of operating with good-to-excellent performance at many different frequencies simultaneously. Normally standard antennas have to be "cut" for the frequency for which they are to be usedand thus the standard antennas only work well at that frequency. This makes the fractal antenna an excellent design for wideband and multiband applications."
The trick is to design your fractal antenna to resonate at what ever center frequency you wish to receive. Which means it will look different and be sized different depending on what you want to receive. A little math can be used to figure this out. (Or a online calculator)
In my example, I am going to make a simple one but you may want to make a more elaborate one. The more elaborate the better. I will use a spool of 18 Gauge solid core wire to make a antenna as an example but you could go as far as to etch your own circuit boards for aesthetic reasons, to make it smaller, or more elaborate with more resolution and resonance.
I am going to use the example of making a TV antenna for digital or high definition reception for over the air broadcasts. It is easier to work with these frequencies and they fall around half a foot to a few feet in length for half wavelengths of the signal. I am also going to base it off a common dipole antenna for simplicity and cheapness of parts for VHF. For UHF you may want to add a director or reflector which will also make it more direction dependent. VHF is direction dependent as well but instead of pointing directly at the TV station like UHF you want VHF rabbit ears (dipole antenna) to be perpendicular to the TV station. But there is a little more design to that. I want to keep this as simple as possible as it is already a very complex subject.
Basic supplies (cost me about $15):
Mounting surface such as the plastic project enclosure (8"x6"x3"). http://www.radioshack.com/product/index.jsp?productId=2062285
6 screws. I used steel self tapping sheet metal screws.
A impedance matching transformer 300 ohm to 75 ohm. http://www.radioshack.com/product/index.jsp?productId=2062049
Some 18 gauge solid hook up wire. http://www.radioshack.com/product/index.jsp?productId=2036274
RG-6 coaxial with terminators (and rubber jacket if mounting outside).
Aluminum if using a reflector. The enclosure above came with one.
A sharpie marker or equivalent preferably with a fine tip.
Two pairs of small needle nose pliers.
A ruler of at least 8 inches.
A protractor to measure angle.
A drill and drill bit that is smaller diameter than your screws.
Small wire cutter.
Screw driver or screw gun.
NOTE: The bottom of the antenna is to the right of this picture where the transformer sticks out.
Step 2: Drill holes and add mounting points
Step 4: Measure and mark wire
Step 5: Create fractals
Step 6: Create dipoles
Step 7: Mount dipoles and mount transformer
Attach the impedance matching transformer across the two center screws and tighten them down.
BUILD COMPLETE! Test and enjoy!
Step 8: Testing verses store bought antenna
http://ruckman.net/archives.htm#DTV
ENJOY!
Step 9: More Iterations / Experimentation
Photo attached. It may be hard to see with the photo taken in low light, the color of the cardboard, and the color of the copper with tape over it to hold it in place. But you get the idea.
At that size the elements are pretty fragile, so they have to be handled carefully.
I have also attached the template in png format. For it to print the proper size, you have to open it in a photo editor like Gimp. The template isn't perfect as i made it by hand with a mouse, but it is close enough for human hands and a needle nose for bending of the elements.
Enjoy.
![011609_1458[00].jpg](/files/deriv/F9Q/8UOB/FPWWQXAY/F9Q8UOBFPWWQXAY.LARGE.jpg)
Visit Our Store »
Go Pro Today »
Enjoy.
bending the wires is a little time consuming, but in theory it should add more stable reception. i thought it might be helpful if anyone else was curious about increasing the fractal bends.
Attached here is a pdf for use as a guide / template.
Also, this can easily be mounted to cardboard, pexiglass etc and placed INSIDE the project box, to conceal the antenna.
Thanks,
but the fractal design is smaller and safer (no pokey bits sticking out).
Thanks
with increased fractals (like the pdf above) i now get 88 scanned channels (southern california). that's a pretty significant improvement.
With the reflector and this type of antenna, directionality is key. By shifting the antenna's azimuth by only 12 degrees East, we lost Santa Barbara and began picking up Mount Wilson's signals (pretty much all Los Angeles channels), also from San Diego (only 100 or so miles away); still damn good, however, reception is tightly locked, though also *very* stable. Sans reflector, there is an increase in the number of channels from adjacent broadcast antennas, with additional stability introduced from the fractal design.
Great job.
we used the increased fractal design as a basis (same perimeter). We then mounted the antenna on the focal point of a Dish Network satellite dish, with the dish facing North, from San Diego. The dish sits on our balcony; second story, though we also have trees in the way. It has been several months since the system was put in place and we still receive 50+ channels, mostly from Los Angeles, though we also receive adjacent channels from San Diego.
I few years ago, I bought and put up the most powerfull antenna that Wineguard makes. I live a little way down from the top of a hill in National City. The antenna, 9 feet by 14 feet was raised 48 feet from the ground. I was able to get a lot of channels out of LA as well but they were unstable coming in out all the time. The wind from a storm in Dec of 09 blew my telescoping pole system in half. And that was the end of that. But you managed to do the same thing with far less. Are your LA channels and beyond stable? Thanks for your input jkunkin and waiting your reply. garrison 111
yes, the satellite dish increased the gain quite a bit. The antenna is mounted vertically, not on its side, and in fact, most of the stable LA channels the antenna receives are in the VHF range (2 - 13), in addition to a variety of foreign language channels in the UHF range, of course. This is remarkable since DTV reception is based on the UHF range, afaik. One of the keys to stability is minimizing the use of splitters, since the signal can drop by several dB, as well as keeping coax cable lengths to a minimum; the longer the cable the greater the reduction in stability, say, if the cable is moved around. I believe tripods and satellite dishes can be purchased for around $100 from companies selling OTA receivers.
Good luck with your project.
It's great that this antenna can pick up both UHF and VHF bands. On the loss of db, if an amplifier is placed close to the antenna, that should compinsate for line loss.
On the dish search, I jsut remembered. I believe and have seen them being sold on craigs list pretty cheap.
Thanks again and waiting your reply. ~~ garrison111
I built the fractal antenna shown in the attached picture. Works great. I am 35 miles south of Milwaukee, WI and I receive 20 - 30 stations clearly. I can get Chicago stations but I must rotate the antenna.
Please comment on the circular design that I plan to build. Will it work if there are 20 fractals on the large diameter and only 11 on the small diameter. The large circle is 20 inches in diameter. The small circle is 18 inches in diameter. The fractals are approximately 3 inches tall.
Thanks for posting you instructions for the fractal antenna. Much better than my V shaped coat hanger design.
Sorry if I get multiple images. ??????
Thanks
Took me less than 30 minutes to toss together. I just put some aluminum tape on the back of the chunk of scrap wood I built it on as a reflector - not optimal but seems to work just fine. Even if I count my wages for the time spent making it I'd say I'm time and money ahead vs. buying another commercial antenna - took me less time to build this one than it did to find a good deal on the last one I bought. And no waiting on shipping :)
The only downside is that 1 hour of TV last night reminded me why I don't bother with cable or sat anymore and seldom turn the TV on even when I have a working antenna :)
