Step 2Drill holes and add mounting points
All Steps Viewing
bending the wires is a little time consuming, but in theory it should add more stable reception. i thought it might be helpful if anyone else was curious about increasing the fractal bends.
Attached here is a pdf for use as a guide / template.
Also, this can easily be mounted to cardboard, pexiglass etc and placed INSIDE the project box, to conceal the antenna.
but the fractal design is smaller and safer (no pokey bits sticking out).
Thanks
with increased fractals (like the pdf above) i now get 88 scanned channels (southern california). that's a pretty significant improvement.
With the reflector and this type of antenna, directionality is key. By shifting the antenna's azimuth by only 12 degrees East, we lost Santa Barbara and began picking up Mount Wilson's signals (pretty much all Los Angeles channels), also from San Diego (only 100 or so miles away); still damn good, however, reception is tightly locked, though also *very* stable. Sans reflector, there is an increase in the number of channels from adjacent broadcast antennas, with additional stability introduced from the fractal design.
Great job.
we used the increased fractal design as a basis (same perimeter). We then mounted the antenna on the focal point of a Dish Network satellite dish, with the dish facing North, from San Diego. The dish sits on our balcony; second story, though we also have trees in the way. It has been several months since the system was put in place and we still receive 50+ channels, mostly from Los Angeles, though we also receive adjacent channels from San Diego.
I few years ago, I bought and put up the most powerfull antenna that Wineguard makes. I live a little way down from the top of a hill in National City. The antenna, 9 feet by 14 feet was raised 48 feet from the ground. I was able to get a lot of channels out of LA as well but they were unstable coming in out all the time. The wind from a storm in Dec of 09 blew my telescoping pole system in half. And that was the end of that. But you managed to do the same thing with far less. Are your LA channels and beyond stable? Thanks for your input jkunkin and waiting your reply. garrison 111
yes, the satellite dish increased the gain quite a bit. The antenna is mounted vertically, not on its side, and in fact, most of the stable LA channels the antenna receives are in the VHF range (2 - 13), in addition to a variety of foreign language channels in the UHF range, of course. This is remarkable since DTV reception is based on the UHF range, afaik. One of the keys to stability is minimizing the use of splitters, since the signal can drop by several dB, as well as keeping coax cable lengths to a minimum; the longer the cable the greater the reduction in stability, say, if the cable is moved around. I believe tripods and satellite dishes can be purchased for around $100 from companies selling OTA receivers.
Good luck with your project.
It's great that this antenna can pick up both UHF and VHF bands. On the loss of db, if an amplifier is placed close to the antenna, that should compinsate for line loss.
On the dish search, I jsut remembered. I believe and have seen them being sold on craigs list pretty cheap.
Thanks again and waiting your reply. ~~ garrison111
http://www.kwarc.org/ant-calc.html
Thanks for the instructable! It is really cool. I came across your design the other day and decided to try it out this past weekend and it worked pretty good, just in my living room and with no reflector. My antenna is made with 8 dipoles instead of 4. I sort of combined your design with the bowtie design. I was able to pick up all the same channels as my two uhf only antennas from Radio Shack. Granted I had to rotate the antenna to aim it in the right direction and not all signals came in as strong.
The antenna is not totally finished. It's still missing a reflector. I've read on some other sites that wire mesh might work better as a reflector, as opposed to a sheet of aluminum. What do you think? Also, is the distance between the dipoles and the reflector important? My dipoles are on mounted on 1/2" plywood stick. If I put the reflector on the opposite of the plywood, would it be too close?
I am going to try to add this antenna with my existing two in the attic and combine all the signals into one to see if it will improve my reception. I plan to point all three in slightly different directions to be able to pick up all the stations. I don't have a rotator.
Thanks again for the cool design.
They both work really well, One has a balun one doesnt..They both are superior to
the amplified & unamplified rabbit ears. The next time I make another I will probably solder things together and better the construction.
Thanks for the plans
Sorry for being such a noob, but I want to really make this and need some clarification on this part of the assembly.
I see now, thank-you.
