3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a fractal antenna for HDTV / DTV plus more on the cheap
Step 6Create dipoles
Create dipoles
Cut 2 more pieces of wire at least 6 inches long and strip them. Bend these wires around the top and bottom screws going longways and contact the center screws. So all three are contacted. Use the wire cutter and trim unneeded wire.
5 comments
May 19, 2009. 5:07 PMmelmocca says:
are you sure that the reception you received could be as well be received by the dipole by itself?
Jul 16, 2010. 4:16 AMWeegee097 says:
The fractals are the dipoles. The line in between is called the phasing harness. It picks up extremely little.
Mar 24, 2010. 7:36 PMka irnie says:
sir good day,
                      if i will use a balun for this fractal antenna ,what impedance should i use?ntx.
Jul 16, 2010. 4:17 AMWeegee097 says:
A 300ohm to 75ohm Matching Transformer/Balun. Hope this helps.
Aug 11, 2010. 6:34 PMka irnie says:
Good day sir, I already made my prototype of this fractal antenna, I follow your suggestion to put a Balun 300/75 ohm matching transformer.Unfortunately I cant test it here due to that our broadcasting here is still analog,Have you tried this in your country? BTW I live here in the Philippines. Tnx. Best regards.
Jul 16, 2010. 9:53 PMnelu57 says:
750 ohm ? or 75 ?... Attention that you did wrong here !!! You know what you say?
Jul 19, 2010. 4:14 AMWeegee097 says:
Don't you know the difference between a o and an 0???????? I clearly said 75ohm! Also consider learning English before correcting me. "You know what you say?".
Jul 19, 2010. 1:11 PMnelu57 says:
Sorry if I wrote was wrong, but it can not read well. Makes you a space between words. Sorry of English spoken. I use a programme of automatic translation. Only good news.
Jul 20, 2010. 1:45 AMWeegee097 says:
Um, if you can't even speak a little English without a convert tool, then don't try instructing me on proper grammar.
Jul 20, 2010. 3:17 PMnelu57 says:
Professor you never wrong ? ... You get a perfectly man? at the age which is shown ? To no longer asked in vain Ok.? End !
Jul 20, 2010. 6:45 PMWeegee097 says:
You, sir, are very insulting, and I suggest you stop spamming my posts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
43
Author:williamruckman
