How to make a fuse.
How to make a fuse.
This is an easy fuse to make. It burns really slow, like 5mm per sec.
Step 1Stuff you need.
To make this you need:
Potassium nitrate (can be made explain later)
Potassium clorate (can be made explain later)
Powdered coal ( Can be made by crushing coal)
Sugar
water
contaner
sring
sorry no pic for this step.
24 comments
Mar 23, 2011. 7:33 AMjhumm15 says:
If you use only potassium chlorate or only potassium nitrate with just the sugar and some hot water it will only burn at approx. 3.5 inches per minute depending on how you mix it.
recommended mix is:
1 part potassium chlorate
1 part granulated table sugar by weight
then 2 parts hot water.
should come out to a thickish paste like elmers glue
Jul 29, 2010. 9:44 PMclzfishing says:
Isn't it easier to just take a string and rub wet sparkler powder on it
Nov 29, 2009. 1:20 PMgkrmelj says:
Getting the materials is harder than getting a fuse, lol!!!
Sep 3, 2009. 7:46 PMbackyardpyro217 says:
wow just imagine if you added this stuff to napalm!
Dec 19, 2008. 4:22 AMPyrochemistry says:
hmm well this is quite a silly way to make a fuse. considering mixing potassium chlorate and charcoal = H3 which is highly explosive..i suggest just making black match but if you are willing to risk making an explosive..lol well hell, go for your life :)
May 3, 2008. 7:19 PMcobrasniper555 says:
It can't explode spontaneously. KClO3 (potassium chlorate [spelling!]) in a mixture of some form of carbon is known as H3 and is only sensitive. Being that you add KNO3 (potassium nitrate), there is added oxygen for combustion with the sensitivity of KClO3. This is a horrible idea. Please don't post something like this again. Just mixing methanol with ammonium nitrate (WON'T make Nitric Acid; if you think otherwise, try to make an equation!) is a bad idea because mixing chemicals without knowing chemistry or anything about what could happen is stupid enough. I'm sorry to get on your case brookech but if you can't: A) Throughly explain such instructions; B) explain backgrounds of the chemistry, then you would be better off just not putting up an instructable like so. Thank you, Brent
Aug 30, 2008. 8:38 PMTombini says:
I agree with cobrasniper, AN + Metho does not make nitric acid!
CH3OH (methanol) + NH4NO3 (Ammonium Nitrate) =
Little or not reaction, methanol is stable and AN decomposes...
Can anyone find the reaction?
Jun 21, 2008. 9:31 AMTMan0314 says:
the best fuse is just unroll a cotton ball and twist it real thin then light it.
Dec 5, 2007. 3:45 AMMadMechanicMike says:
it wont explode in the sense your thinking. it will just poof like a small pile of gun powder. theres no pressure build up therefore there cant be a harmful explosion. unless of course you put your face directly over the compound while its rapidly burning ("exploding")
Mar 22, 2008. 7:48 PMandrew_29 says:
to get an explosion u nead a sealed container and it probably wouldent spontaniously combust inless it was out in the sun
Jan 28, 2008. 4:52 PMDeusXMachina says:
Umm, adding methanol to ammonium nitrate is just going to give you nasty gunk . You need concentrated sulfuric acid. I was gonna add how, but then realized, oh crap, 90% of people trying to do that would kill themselves because it involves lots of toxic gas and acid spatter. If you really want to, look it up on the internet. lawl methanol....who comes up with this stuff?
Jan 29, 2008. 9:12 AMDeusXMachina says:
step 4:Make the stuff! (optional).
To make potassium nitrate add methanol to ammonium nitrate
(fertilizer) to make nitric acid and add anything with potassium in it.
I'm not saying it to anyone in particular just anyone who might try it. No point in wasting methanol and/or NH4NO3 and time.
Jan 5, 2008. 9:55 PMPyroFun says:
your fuse seems like it would work very effectively, it uses too many things in my opinion though, could make a good fuse with half that stuff
Nov 20, 2007. 9:19 AMtech-king says:
if it explodes after it dries into a paste, what stops it from drying and exploding on the string??
Nov 19, 2007. 3:09 PMkruser495 says:
all these are really unnecessary. you dont need potassium chlorate or sugar water. take a mixture of kno3 and charcoal and ball mill it. that will give am mixture to coat the string in.
Nov 19, 2007. 12:22 PM!Andrew_Modder! says:
cool, i love making fuse! Also to make it waterproof you could add dextrin, white glue, or hair spray the wire when its done drying (or you could do all thos things lol)
Nov 19, 2007. 12:42 AMalya says:
(removed by author or community request)
Nov 19, 2007. 7:43 AMuguy says:
what video? flagged
Nov 19, 2007. 1:46 AMPocketSized says:
You seem to be speaking off topic here. And to no surprise you've mentioned www.s*tree.com. Just like you have in all your comments you have made so far. Nice Instructable brookech
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:brookech
