This instructable involves sculpting, vacuum forming, and basic electronics (ElWire)
It was a very hectic process, and I learned a lot doing it - mostly by finding out the hard way what not to do.
So, in this instructable, I will talk you through the process of making a suit like this, and share with you the pitfalls that I encountered, so that you can avoid making the same time-consuming mistakes that I did!
Remove these ads by
Signing UpStep 1Materials
Vaccum Former
- Very easy to make. I built mine off this instructable
- A more fancy version can be found here& here
Soldering iron
Stanley knives
Wire Strippers
Hot glue gun
Mannequin torso
Mannequin arm
Friends to help you! (not essential, but makes the process much easier)
Materials
(the exact quantity of materials required will vary depending on the design of your suit)
Base armor shapes:
Clay
Plaster
Thin thermoplastic (we used 0.5ml HDPE)
Armor plates:
Thicker thermoplastic (we used 1ml HIPS)
Black spray paint
Metallic spray paint (get the good stuff. You won't regret it)
Rare earth magnets or marine-grade press studs
Hot glue
Under suit
Black skivvie
Black balaclava
Black thread
Electronics:
ElWire
ElWire Connectors
ElWire Inverter
Dual Core Wire
Solder
Heat shrink tubing
6
comments
Add Comment
Add Comment
