How to Make a Great K'nex Weapon Instructable by Mepain
Step 2: Barrel types
Two types of barrels were explained in the last step. There is a third type, the barrel-hopper combo.
A hopper is basically a compartment that holds ammunition until the ammunition is ready to fire, and the hopper will feed it into the barrel. The hopper is called many things-hopper, magazine, clip, etc.-and each one is a slightly different part on a real weapon, however, they are all accepted as the same thing in the world of K'nex.
One example of a good hopper-barrel combination is crestind's AST Rifle.
Another great combo is Ipod Killer's Sniper Rifle.
The best combination is probably the barrel of Perfect Duck's Red Impact because it lacks the friction that most hopper-barrel combinations have.
flamely says: Jan 29, 2008. 11:50 AM
i have an idea in my head for a great barrel i made it but shoots only 30 ft but from 30 ft i was able to hit a can so it is accurate but how do i strengthen the barrel note: the barrel i made has hardly any friction also i cant put pic bc i cant find a camera atm
Sketch98 says: Jul 17, 2010. 5:16 PM
more rubber bands, thicker/stronger rubber bands, etc.
riggles says: Apr 13, 2009. 2:48 PM
which barrel is better the one where it goes in between the circle in the connector or when it goes between 2 connectors?
JonnyDude2008 says: Jul 6, 2009. 4:41 AM
The one that goes inbetween the two connecters is allot better because it uses a sling shot firing system where as the circle barrel as you put it requires a ram rod which is not that long meaning less power and there is more friction meaning less power again.
noobererer says: Aug 7, 2009. 6:10 PM
not really...i mean its better but it isnt always slingshot...its ram rod alot of the time between 2 connectors...and yes slingshots are more powerful but ram rods can have mags....and yes u could add a mag on a slingshot gun but it would pretty much BLOW :P
noobererer says: Jun 25, 2009. 6:27 PM
yeh ive always wondered that too
riggles says: Aug 7, 2009. 5:57 AM
Thanks i've been trying to figure that out! no I'm gonna try to make a really long cannon =) its just basically a big barrel with a string that u pull thx!
u replyed to wrong guy but NP! lol
Alirocks1 says: Apr 12, 2009. 12:20 PM
Mmmm qeustion plz reply How long is de fire pin most likely in long guns like these?
erikos kostarikos says: Apr 22, 2009. 11:56 AM
the length of a grey rod. ben je nederlands??
happybirthday says: Dec 9, 2008. 11:18 AM
isnt a hopper a mag that goes on the top?
knexsuperbuilderfreak says: Jan 16, 2009. 8:22 PM
yes
happybirthday says: Mar 16, 2009. 11:43 AM
new image!?
knexsuperbuilderfreak says: Mar 16, 2009. 1:46 PM
so what i cant get one
happybirthday says: Mar 16, 2009. 2:19 PM
I was just so used to the old one.
knexsuperbuilderfreak says: Mar 24, 2009. 4:32 PM
oh
happybirthday says: Mar 24, 2009. 7:43 PM
yeah
cstrike pwner says: Sep 23, 2007. 1:11 PM
i don't know how clips work on guns
Miles Tails Prower says: Dec 7, 2008. 10:46 AM
The firing pin is pulled back. Because the firing pin is pulled away, the bullet falls from the hopper into the barrel, and when you pull the trigger the firing pin is released, pushing the bullet out of the barrel, and the process begins again.
realcelestialphoenix says: Aug 2, 2008. 10:47 AM
(removed by author or community request)
TigerNod says: Sep 18, 2008. 5:50 AM
In that case, I only using clips because they are less likely to jam.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
