Introduction: How to Make a Homemade Dremel Tool
About: A YouTuber and maker hobbyist trying to get a better hold of life and stuff!
If there's one thing that any crafty person, like myself, hates more than getting some inspiration for something cool to make, its not having the right tool to use to make that cool thing. One tool that i can think of that many with a low budget would love to have is a dremel. Since i can't use my school loans to pay for a reliable dremel with various bits from a hardware store, why not make my own dremel instead and have enough for the bits once its done?
UPDATE
I have a Soldering Iron now so getting a bit holder to stay on the motor should be easier now! I'll post that in a few days (When i can figure it out...)
UPDATE 2
I plan to remake this now that i know dremel chucks can be sold on Amazon.com. I shall buy one and make a better homemade dremel for anyone that looks at this.
Step 1: Parts List
Shopping List:
1. x2 9v batteries
2. x2 9v battery plugs
3. Switches (1 for pulse, 1 for power)
4. Electrical tape
5. 9-18v electric motor
6. Hookup wire, preferably red and black
7. wire cutters & strippers (i just used my trusty multitool)
8. Cardstock (about 2-3 sheets)
9. scissors
Sure there's tacky glue in the second picture, but i didnt use it. thought i would, but thats why i had the electrical tape.
Step 2: Red Wire Switches Hookup
From the motor, take some red hookup wire and split it into 3 pieces with the ends stripped off to connect the switches to the motor. be mindful of the power switch. when i was almost done with making this dremel, i had to take out the power switch and put it in the other way. so make sure you know which way the switch goes before you put on the cardstock body.
Step 3: Battery Connectors
At first, i forgot that you connect the power to the ground wires to make this work as a complete circuit. So for the two power connectors, take and combine one power and one ground  wire from each connector and twist-tie them together. Secure with electrical tape.
Afterwards, take a section of black hookup wire and do the same for the other ground wire on the battery connectors. hookup and tape the new extended ground wire to the motor. twist-tie and tape the power wires to complete the circuit.
Step 4: Cardstock Body
Roll the cardstock around the motor and put a piece of tape to secure it. With the circuit at full length, see where the switches can be placed on the tube. i put the power where i could turn it on with my pinky finger while the pulse can be pressed with my thumb. cut some holes with the scissors to a size that the switches can be pulled through, then cover the edges of the holes with electrical tape. the switches should fit snug in the body.
with the battery plugs dangling from the bottom of the cardstock body, connect the batteries and tape them to the lower side of the dremel. If the body doesnt seem strong enough to hold everything together, add some more cardstock and electrical tape for a thicker body with good grip.
(sorry about the 5th picture, i didnt think it would look like that.)
Step 5: Add Some Flare (if Ya Wanna)
Congrats! you have just made a half dremel out of parts you can get at a Radio-Shack and a Wal-mart for less than $30!
Ill try to post the bit holder sometime this week if i can figure it out.
3rd Epilog Challenge
