3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a hopper for an airsoft gun out of an old bottle
If you always run out of bbs when using a machine gun then this is for you.
You will need
2 water bottles of the same kind
hot glue
airsoft gun that needs a hopper
Step 1Putting on the "adapter"
This is the most important part because if this isn't made right then you won't have a good hopper.
Start by taking a cap and poking a hole in it and then make the hole larger like it looks in the picture below
Then glue that cap on like in pic 2 so that it goes over the place where you would usually put the bbs in
12 comments
May 25, 2011. 6:01 PMmgermanovich says:
is the gun good?
Aug 13, 2010. 9:39 AMpaintballer97 says:
What kind of gun is that?
Jan 31, 2011. 6:11 PMAir_Assassin says:
The gun is called cyber gun defender
Jan 28, 2011. 2:49 PMthing 2 says:
It's a little $20 gun you can get from walmart.
Nov 29, 2010. 7:47 PMjoshfedo says:
its a AUG
Sep 28, 2011. 7:31 PMilpug says:
Amazingly Useless Gun.
May 24, 2009. 10:50 AMzimmemic25 says:
in step 3 u say "I chose a big bottle, that holds about 3000" is it the same as in picture 1 in the intro? i think that holds more than 3k... i bought one of these BB packs with 3Kx6mm BBs and that were less. or the bottle looks bigger than it is. do you think i can use a 1.5 liter plastic water bottle? or will it be too heavy/big? if it is to big, i could try to make some sort of mechanics that fills the BBs from one or more bottles in my backpack into this thing u made in step 2. oh and in step 2 u say "This will keep bbs from falling out Pic 2" but i can't see any Pic 2... and how can i use a piece of plastic if i threw it away?
Aug 7, 2009. 1:40 AMzimmemic25 says:
i thought of using a motor driving a screw which would push the BBs into the tubing, because then i could have the gun above the level of the bottle, because the BBs don't roll through the tubing, they're pushed.
Aug 7, 2009. 1:42 AMzimmemic25 says:
ill build that "BB backpack", and then ill make an instructable about it. maybe even with a small vacuum cleaner-like thing for easy collecting of BBs that are laying around on the ground...
Feb 11, 2009. 5:08 AMnerfer says:
sweet, dude!
Jan 15, 2009. 10:17 AMevanwehrer says:
Darn, I was gonna post an instructable like this, good job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:TitanTechRobotics(Titan Tech Robotics)
I like regular robotics and combat robotics. I also like just about anything that has to do with instructables.
