3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a layered oak bow (or How NOT to make a pyramid bow)
I've been wanting to make my own bow for a while and I had been reading up on it for a couple weeks when I decided to give it a go. I figured I'd make a pyramid bow based on Tool Using Animal 's instructable, found here . (Props to him by the way. Great instructions. I just didn't follow them very well)
To give you a heads up, I did not end up with a pyramid bow, and the bow I ended up with has about a 30 lb draw, but I decided to put this here so others could learn from my mistakes, or maybe adapt what I came up with to suit their needs.
This is what I ended up with...
Step 1Gather Materials
Gather Materials
I started out with :
1x3x8 oak
tape measure
jigsaw
Stanley SurForm wrasp/plain thing (good for shaping wood, and actually used it to remove up to about 1/4-3/8" at various times)
I ended up also using:
Table saw
Bow saw
Chisel
Bench vise
Wood Glue
Screws
Twine
3/8" dowel
Drill w/ 3/8" bit
...may hav forgotten 1 or 2 things...
3 comments
Oct 19, 2011. 10:37 PMelectfire says:
Ha, you had better luck than on the bow I was working on! I had made a two layer bow (I don't remember quite the woods I used but it wasn't cheap)... Anyways I had it almost finished...and in a hurry to test it, I didn't let the glue dry nor did I tiller it... anyways I strung it - it was ok.. I started to pull on the bow string and SNAP! the wood split rendering all the work I did pointless... looking back I should have let the glue dry longer or just do a single layer type bow, I should have added reinforcing pins/pegs.. and I probably should have tillered it once I strung it... oh well - I gave up for now on making a bow and bought a small bow...(child's - but perfect for practice) though I couldn't find a basic bow (though I was at the Evil Empire (Wal-mart)..instead of someplace better suited...) So I got the one I found for about 25$ not too bad for a little compound bow, that's good for practice.. though I have to say it's going to take quite a bit of practice to master as I have never used a compound bow before...
Aug 29, 2011. 10:30 AMzazenergy says:
Thanks for sharing your experience making this. Sometimes the best Instructables are the ones which help us learn from others' mistakes!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:RCS82
I enjoy building things. There is something quite satisfying about making something from various parts, rather than just buying it. Also, I tend to be a bit frugal. So, many,if not all, of my projects...
more »
