Step 2Building the base
As for my base, I build it using a Styrofoam board cut into 2 block of 15cm by 15 cm. next I grove a hole on the Styrofoam for the bulb to sit onto.
I use a 200V lightbulb and connect it to a power source. You can experiment with different colored LED light or even use christmas light for this. Make sure the base is high enough so light don't escape through the bottom. Try sticking 2 blocks of Styrofoam together with double sided tape.
Give a general description of the Step
Add Comment
