3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a magical two headed coin
In this Instructable, you will learn how to make a 2 headed, and mutilated coin, to use for magic, or other purposes.
Step 1Materials
Materials
The materials you need:
>2 nickels, or two identical coins
>Superglue
>Sandpaper (Bench grinder works better)
>Dust Off (with the little straw)
41 comments
1-40 of 41next »
Jun 21, 2009. 2:19 PMMrsPost says:
Defacing US currency is frowned upon. Perhaps a token or other non-protected coin shaped object would be in order?
Sep 8, 2011. 7:54 AMwhiteboyninja says:
its only illegal if you make the currency appear to be worth more than it is. thats why its legal to have penny presses.
Jun 22, 2009. 8:10 AMjunits15 says:
Anything worth less than $0.25 is ok to destroy
Sep 12, 2010. 9:25 PMDirkByrd says:
do we have a reference for that?
Sep 20, 2010. 3:25 PMeulaliaaaa! says:
It is fine, unless you try to put it back in circulation. The common misconception is that it is illegal to "deface" the coins or bills. It is perfectly alright to do whatever you would like with currency. It is your money, and it is alright unless you try to make it someone else's (a.k.a. putting it back in circulation, a.k.a. buying stuff with it.).
Aug 19, 2011. 10:07 PMbwoodruff2 says:
Wow that was stupid
Jul 31, 2011. 11:32 AMzjschafer says:
I own a real two heads sided nickel! Anyone know what it may be worth?
Aug 4, 2011. 6:48 AMDreamTheEndless says:
It was not made by the US Mint - it was made similarly to this one, but it was just done more perfectly. It might even be worth $1 if you found someone interested in it.
Aug 4, 2011. 12:14 PMzjschafer says:
It is a 1954 nickel, two heads on both sides. Look for yourself, it is the same width and size of a real nickel as itself. It has some wear and tear, but i think its real. What you think?
Aug 4, 2011. 12:01 PMzjschafer says:
alright, but it used to be my pap's. he gave it to me and he told me it was probally worth more cause he said somebody offered him $35.00 for it. The government doesnt like to make mistakes so they would pay a lot for it. he knows a lot about collectors items and coins. so i dont know, thanks for the advice!
Sep 8, 2011. 7:53 AMwhiteboyninja says:
the coin is actually nothing more than a novelty item. its made by sanding off the edge and the tails side of the coin then placing that into a hollowed out coin. most are only worth ten dollars at the most. that one may be worth a little bit more because in 1954 nickles and other silver coins were still almost one hundred percent silver. from the way it appears in the picture there was one mistake made when the person made it. the way you r turning the coin, on of the heads should be upside-down. but its impossible for a double headed coin to be made by mistake.
May 6, 2011. 7:59 PMl99roufs says:
Couldn't you cut and/or sand off half of each coin?
Nov 3, 2010. 8:11 PMballoon popper says:
on youtube ericsurf6 teaches you how to always win
May 26, 2010. 12:29 AMwalking encyclopedia says:
a WAY BETTER way to do this is get three band new pennies.  On the bench grinder, shave the face off one, the back off one, and both sides of of the other one.  Thes in some muriatic acid. The acid will polish the copper shell and eat the inside metal.  Watch it closely off and on for about 30 minutes.  After this you have a perfect face, back and side ring.  You can grind of a fourth penny's faces and side then glue it to this one.  However, I like to to take a little piece (tiny of lead) and put it inside.  Then just glue it shut with a big air pocket.  This makes for an even cooler trick.  THE FLOATING PENNY that looks feels and weighs the same as a regular penny.
Jul 27, 2010. 11:34 AMcrazyg says:
wonderd where you were going with this but floaty penny cool
Jun 30, 2010. 10:05 AMTreknology says:
I knew that milling machine downstairs would be useful for something...
Jun 30, 2010. 1:24 AMArchive555 says:
I made one of these once, you can do a pretty good job of removing hte tails side with a dremel, and it works really well for making the edges of the coin smooth, too.
May 15, 2010. 11:21 AMrockgod57 says:
regular sandpaper wont work though it just rips so u would need a bench grinder
May 30, 2010. 5:27 PMGhostfox21 says:
Or a file
May 30, 2010. 6:43 PMrockgod57 says:
good point never thought bout that also i recently saw a sanding sponge its slow but it works (kinda)
May 30, 2010. 7:18 PMGhostfox21 says:
I'll have to look into that sponge thing, I've never heard of them before.
May 15, 2010. 11:17 AMrockgod57 says:
also instead of  dustoff id take a more dangerous approach (danger is awesome) and open up one of those airhorn cans and use the liquid in there (which can actually give u frostbite) to pour on the coin with the super glue.
May 8, 2010. 5:11 AMrockgod57 says:
cool i gotta try it out but i dont get why you would super glue it for a second time does it change color or what
Oct 17, 2009. 9:32 PMrenscan2 says:
 This is how to do frozen by adam grace!!!
Dec 9, 2009. 11:30 AMSorcerer1089 says:
No no no. This is how to freeze a coin with a can of dust off. Frozen by Adam Grace is making a coin freeze by magic.
Jun 21, 2009. 6:58 PMJohn Smith says:
whats the point in freezing it again? colder temperatures make the superglue evaporate slower i thought.
Oct 30, 2009. 3:22 PMVater Araignee says:
Spraying it with water will help it dry faster and turn it your white color.
Why you would wish a much more detectable color is beyond me.
Jun 23, 2009. 3:41 PMmoo of the cow says:
do you have to use the dust off freeze thingy????????
Aug 23, 2009. 8:57 PMberky93 says:
you shouldnt have to. it just helps. a freezer would probably work too, or just letting it sit for 48 hours (to be safe.)
Jun 27, 2009. 6:45 PMSurferGeek says:
Perhaps another way, rather than a jeweler's saw, would be to sand the coin down to approximately half their thickness and then glue them together. By the way, defacing ANY currency is only illegal if you have the intent to pass it off as legitimate afterward.
Jul 12, 2009. 6:46 PMAce_Of_All_Trades says:
The law regarding currency defacement is stated and read so that the defacement of currency is illegal only if it is used for fraudulent purposes. Now if you want you could use pennies to be "double safe", if you will, because they are exempt from the rule. In training to be a sales rep. for Cutco and Vector they teach as that law as we cut and sculpt pennies with our shears.
Jul 4, 2009. 8:55 PMhydrnium.h2 says:
I thought money was government property
Jul 25, 2009. 11:48 PMA good name says:
Well the government belongs to the people. Therefore what is theirs, is ours.
Jun 23, 2009. 10:39 AMAvasar10000 says:
Another way to accomplish this feat is to use a jewelry saw to "split" both coins in to halves. Then sand all of the halves using your favorite sanding tool. You will glue the like halves using JB Weld. When dry, sand the edges with finer, and finer sand paper to achieve a mirror polish. This will produce 2 double sided "MAGIC" coins that are much harder to detect as gaffed coins. You could even add a steel shim to make the coins magnetic. Magnetic and double sided....that would be MAGIC. Take care!
Jun 29, 2009. 7:04 AMcoatesy900 says:
haha, shim.
Jun 23, 2009. 8:33 PMretrac.noremac says:
wow i was expecting something better than just gluing 2 coins together
Jun 21, 2009. 1:49 PMHands Without Shadows says:
Harvey Dent was the district attorney.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:arkabeoeht
