3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a magnetic brake tower thing
to make magnets fall very slowly.
good for convincing people you found a form of antigravity
(no, it isn't antigravity)
now with video
Step 1Materials
materials
for this you will need;
shower door track, or similar shaped aluminum or copper thing (the thicker the metal the slower the magnet will fall)
clear packaging tape
neodnium magnets (need to fit into the track)
plywood board
2 by 4
tools;
xacto knife
drill
screwdriver
24 comments
Feb 28, 2007. 6:32 PMusuck says:
Thats prety cool so u could like put a magnet in a paper plane and call it "landing thrusters"
Sep 10, 2010. 2:23 PMScout Jinx says:
A strong enough magnet for that would be too heavy to put in a paper airplane.
Sep 22, 2006. 1:01 PMlowtherjustin says:
copper and aluminum dont conduct magnetism right?
Jun 29, 2008. 11:02 PMjester_rob says:
I'm just throwing this out there and if im wrong someone tell me, but doesn't this work because the moving magnet creates an electrical current which in turn creates a magnetic field that slows the magnet?
Nov 28, 2008. 8:15 PMchriskarr says:
Congratulations. You've just won the award for Instructables.com's longest unanswered question finally being answered. You are correct; the magnetic field induces an electric field in the metal near it which causes a magnetic field opposing the permanent magnet's downward fall.
Dec 6, 2008. 12:59 PMdombeef says:
COOL lol
Sep 22, 2006. 2:47 PMLord_Vader says:
Though they aren't ferrous this principle still holds because they are conductors-try it with a copper or aluminum pipe, it adds to the flair lol.
Jul 27, 2007. 8:59 AMmagma6 says:
For information, the phenomenon is a demonstration of the Lenz's Law.
Explaination and video of the retail version of the same "toy" on this page
Oct 22, 2006. 10:20 AMTheTruth says:
This principal is used in elevators. If the cables snap, the magnets cause them to descend at a limited rate, using the metal elevator shaft as the conductor.
Sep 26, 2006. 11:40 PMFrenchCrawler says:
When I was little, we used to "roll" a little plastic ball that had a magnet on the inside (I don't even know what it went to) down the front of the fridge. It slowly made it's way to the ground much like this instructable (we used to race two of the "marbles").
Sep 22, 2006. 2:11 AMPeterTheUnGreat says:
Is this the same principal that some of the vertical drop fairground rides use? Neat, simple demonstration. Now someone just needs to come up with a project which uses this trick to solve a problem. Pete
Sep 22, 2006. 12:27 PM_soapy_ says:
Magnetic brakes on buses and trains already use this. There is no pad to burn out, as it is frictionless. (I'm not talking about regenerative brakes as found on electric cars, etc. but regular deisel buses - http://www.mayr.de/english/p_old/brakes/roba_q/roba_quick.htm is an example)
Sep 21, 2006. 5:41 PMlowtherjustin says:
how would thicker aluminum or copper make the magnets fall slower? maybe I missed something
Sep 22, 2006. 12:17 PM_soapy_ says:
The thicker walls have a higher conductance, and so bigger eddy currents form, using more power. Another way is to make the magnet a tighter fit in the tube, as the field will be stronger at the surface then.
Sep 21, 2006. 11:00 PMLord_Vader says:
This is just obeying the laws of Physics like everything :) When a magnet is in motion its magnetic field is in motion as well. Any change in a magnetic field through a closed circut will generate a current (this is how motors work and the reverse, genorators.) So when the magnet is falling through what is essentially a hollow metal tube, current is being genorated around the outside of it. Since you can't just create energy from nothing the energy that is used to create that current is taken from the kinetic energy of the falling magnet. That's why it falls slower. If you break the circut current will no longer flow and the magnet will fall at a normal rate (given that it isn't just adhearing to the metal surface on the outside)
Sep 21, 2006. 7:36 PMTool Using Animal says:
cool, a hysterisis effect I presume?
Sep 21, 2006. 6:15 PMzachninme says:
Wait, isn't this techinically anti-gravity?
(Not to be picky...)
Cool! To up the effect, encase the magnets in something the make them not appear to be magnetic. Plasti-dip?
Sep 21, 2006. 4:41 PMgigman says:
Ya id love to see a video it looks pretty cool. Any way it looks like it could be turned into some kind of cool art project/scupture type thing.
Sep 21, 2006. 4:18 PMTheCheese9921 says:
videos please
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
230
Author:AlexTheGreat
