3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a manual pickgun - wiper insert
This instructable will walk you through the creation of your very own manual pick gun.
A pick gun (in this case a snap gun to be specific) is a tool locksmiths occasionally use in lieu of picking. It's thought that these tools helped those incapable of picking, but really they prove useful, even to the experienced picker. The tool works by bouncing all the pins above the shear line while you apply tension via tension wrench. The goal, as in all tumbler picking, is to get all the lock pins above the shear line at once. This tools sometimes expedites hat by bouncing them all in a bit of a random fashion. If you have no idea what I'm talking about, it's a good idea to find and read the MIT guide to lockpicking.
This particular tool is created using a windshield wiper blade insert. There are plenty of designs floating around the internet, usually using a coat hanger. I just happen to have a surplus of these wiper blade inserts.
Whatever medium you use, it's probably best I tell you that this is not my original idea. I just wanted to share it. Being my first instructable, I expect errors in grammar, punctuation and such. I'll probably even give some false information. I only ask that you take it easy on me when informing me of such mistakes.
Also - NEVER PICK A LOCK YOU DON'T HAVE A RIGHT TO!
Step 1Basic design.
Basic design.
I made these two without a precise design, and they worked out anyhow. I recommend you at least have a good mental image of the finished product. I didn't think to document the first one, so I recorded the steps for #2.
#1 (green background) has a shorter throw
#2 (wood background) has a longer, curved throw, theoretically giving more of a snap.
The only tools you'll *need* are a pair of pliers and/or vice grips and a Dremel or similar grinding tool.
For this tool, it's ideal to use one of the longer wiper inserts (if nothing else, just to have extra material). 20 or 22 inches will do nicely. For anyone wondering, these wiper inserts are the two metal strips found in almost all windshield wiper blades. Save them when you change your wipers, or maybe go scavenge some from the auto parts store's rubbish bins. Sometimes, those guys will collect these for you, if you're nice.
I also use these to make my tension wrenches, since I go through them so frequently (made an instructable for them - see it here).
So, let's get down to it.
I'll be using three different types of bending techniques with this instructable:
The bend - usually 90 degrees. Made by holding the piece with one set of pliers and bending against those pliers with your hand.
The twist - always 90 degrees. Use two sets of pliers, holding the flats of the piece, and twist away from one-another.
The curve - much tricker. Hold the non-flat sides of the piece with two sets of vice grips (pliers would theoretically work), and curve gingerly - so as to not break it along the curve.
One last note - I didn't actually measure anything. I think the best way to go about this is to do what looks or feels right to you.
44 comments
1-40 of 44next »
Apr 23, 2012. 11:03 AMlockpicken says:
Tried this but cant get it to work so now im waiting on my order pickgun from lockpickwinkel.nl
Aug 27, 2009. 5:27 AMpyrorower says:
I'm looking forward to making one of these. Being a locksmith of sorts, I was wondering if you could help me with this: I use my lockpicks to pick whatever locks I can find in my house, but one lock that I have never been able to pick was one for luggage. It's one of those locks that has the 3 dials and a keyhole so that TSA people can open it. Whenever I attempt to pick this lock, the lower half of the pins (the ones that you can see) never come completely down after I push them up unless I stop putting pressure on the tension wrench. Do you know if this is a security feature or if I am simply doing something wrong?
Aug 28, 2010. 11:42 AMxarlock667 says:
Sounds like a set pin. It has no upper pin and is there because, A) They were cheap, or B) for security. Just relax the torsion bar and let it drop. Then open the pins behind it and pop your lock.
Jan 29, 2011. 3:46 AMnutsandbolts_64 says:
Or maybe he was applying too much pressure on the torsion wrench. I know it's an ancient post, but I might as well populate your comments.
Mar 22, 2009. 10:15 AMdannyt1995 says:
Hey i was just wondering how long it takes you to pick locks using a tension wrench and a pick (not this crazy contraption) because im 12 and i can pick some padlocks in 20secs to 1min and i was wondering if i was any good or can most people get that time??
Aug 28, 2010. 11:40 AMxarlock667 says:
20 seconds is not bad at all. I can pick most dead bolts in 20-30 with just raking the pins and using a torsion wrench. Actually picking in 20 seconds is decent and above my level. My fingers are just not that sensitive.
Sep 21, 2009. 7:56 PMmowie says:
well i can pick locks on doors in about the same time as it takes to open it with a key xD but where i live most of the padlocks keyholes are too small
Jul 13, 2009. 5:15 PMAztof says:
what kind of picks do you use?
Apr 21, 2010. 12:17 AMangannchye says:
hi, thanks for sharing. Managed to try  locks that my friend(locksmith)  find them difficult to pick. Guess what?
Btw, I hv difficulty if  pins are at the bottom, (any solution?)  if not, it's the best homemade that I ever come across! Cool!
Jan 5, 2009. 3:47 PMThelonelysandwitch says:
How does this work, I only pick locks with a set of picks, I have never seen any of these.
Jan 8, 2009. 12:56 PMThelonelysandwitch says:
nice
Nov 4, 2008. 7:54 PMberky93 says:
nice - I made a few of these out of paperclips in school once, but when I hammered the end of the paperclips flat to make the pick ends out of them, it was either too brittle or too small. can you get wiper inserts at wallgreens? (I'm sure there are plenty of other places I can get them, but wallgreens is 3 blocks from my house, so its extremely convenient if I want or need to make a new pick) you know, now that I think about it, I also made one of these once out of a coat hanger (also had to hammer the end flat) but it didnt work because I didnt have a file to shape the end. but I just remembered - I DO have a file now! i'm going to try this tomorow.
Oct 8, 2008. 8:34 AMsniper1 says:
nice looks good to be home made and if you know what your doing works great i give ya a 5 good job and good job at explaning on how to do it 5 stars *****
Sep 29, 2008. 4:41 PMsergentslaughter says:
You should spend less time bending wire and more time sanding you table lol
Nov 20, 2007. 1:19 AMRectifier says:
8-10 snaps? So roughly between 1-2 minutes (looks like it would take about 10 seconds per shot to reset the device)? I would say I can usually rake the "average" lock open faster than that, assuming no security pins. On the other hand, have you successfully dealt with security pins with this guy? I've not really had much interest in automatic picking devices of any sort, as the challenge is half the fun, but having an quick way to pop open a security-pinned lock would be pretty neat. Rectifier (Not a locksmith, but a lock hobbyist thinking of becoming a locksmith if he was a bit better at finding those damn false-set pins)
Nov 20, 2007. 10:51 AMRectifier says:
Of course I would never pull a homemade deal like that out in front of someone, heh. It was more of a question as to the concept of pick guns, whether they can handle security pins. I agree that single pin picking is the best technique though... but I always try a rake first just in case it works. My parents' house came with Medecos... can't imagine why the overkill, but I haven't even bothered to try picking them. When I used to live there, when I locked myself out, I would just sit on the porch and wait for them to come home.... They are supposed to be pretty hard to drill, even, I heard. Not that you would want to drill a lock that is worth more than the damn door! You are a real locksmith? If you don't mind, what would you say the biggest part of your income comes from, and what's a good way to find work? Will a shop take a guy on as an apprentice? I used to be an electrician, but after a shoulder injury I have to look for lighter work. I figured since I already am decent with locks, with some practice I could go into locksmithing...
Sep 15, 2008. 10:24 PMstasys says:
Hehe, im only 12, and if i pulled this object out in front of my classmates, they would be SIMPLY AMAZED. no one is sophiticated enough in my class to unterstand that sort of stuff. 5 stars!!!
Jul 17, 2008. 4:14 AMnuclearscience says:
you could probably hurt people with that
Jul 17, 2008. 8:09 AMnuclearscience says:
that would suck cuz then u can't play any video games with hurting fingers
Sep 12, 2008. 5:37 PMJames (pseudo-geek) says:
take some heroin and continue gaming.
Sep 12, 2008. 5:38 PMJames (pseudo-geek) says:
ok ok JK, I dont support using heroin, its the most addictive drug out there.
Jul 20, 2008. 10:39 AMfreerunnin1 says:
u watch futurama dont u i mean pending for a bending... lol
Jul 18, 2008. 5:39 PMbowmaster says:
I pefer a bang pick.
Jul 13, 2008. 3:31 PMchardster says:
I have a question, after you pick the lock, is the lock still useable?
Jun 9, 2008. 12:44 AMsafdar says:
this iz crap
Jan 14, 2008. 1:07 PMfosockingdude says:
materials?
Dec 23, 2007. 10:03 AMbrainspater says:
that may work on some locks.
Oct 31, 2007. 4:42 PMzachninme says:
Ooohhhh! I finally understand how these work! (it basically spins the wire, in a nutshell, to those still in the dark) I've wondered how the heck these things were working :P
Nov 20, 2007. 7:09 PMzachninme says:
Don't loose sleep over it, I understand it now, and I didn't before :P
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:BorisTheSpider
I pick locks for a living. Never pick a lock you don't have a right to.
