Step 2Gut the gourd
iImage Information
This step is a lot like carving a pumpkin. For this step first cut a circle with a key for easy placement later (see picture). Next you need to cut out the top, this will require a steak knife to cut it completely out. As you cut it be sure you cut on an angle, so the lid won't fall through when put back on. To help yourself cut through the dense gourd try putting your thumb behind the knife so the knife acts as a lever. This allows you to slowly and safely work your way around the top, without a chance of the knife slipping.
Next you need to take a small spoon, or whatever you may have, and scrape out the insides. One trick to make the carving easy later is to thin the wall of the gourd where you will be carving.
