Step 4Cut the image
Now the image is fully poked you need to start cutting out the parts. try to cut the pieces of the image from the centre first so you don't need to push on the weakened gourd later. If your design has teeth like mine you should initially cut right by them and then go back later and do the fine cutting. If you are having trouble getting a piece out, try cutting it into smaller pieces so you can narrow down where it still needs to be cut.
As you cut is use the same trick as the top, so you don't cut yourself, and go slowly.
Add Comment
