Introduction: How to Make a Mini Strapless Lace Dress
This versatile belted and laced dress would be perfect to go clubbing, a dinner or even prom! As you all might know, I'm a big fan of pink, but you can definitely make it in another color.
Step 1: You Will Need
Fabric: Lycra or jersey, Lace.
Measuring tape.
Chalk.
Pins.
Sewing machine.
Scissors.
Elastic band.
Step 2: First Step
Let's start by making the Top.
Picture #1 and Picture #2: First measure the width, in this case 42 cm.
Primero mide el ancho del top, en este caso es de 42 cm.
Picture #3: Then cut the fabric
Luego corta la tela
Picture #4 and Picture #5: Make sure tu pin together the fabric, to make sure when you have to sew.
Asegúrate de asegurar la tela con los alfileres, para luego coser
Picture #6: Fold the fabric as you can see in the picture
Dobla la tela como puedes ver en la imagen
Picture#7: And safe the fabric with pins.
Y asegura con alfileres un extremo de la tela.
Step 3: Second Step
Now let's make the skirt.
Picture #8: measure the length you want and the width has to be the double of your size (waist)
mide el largor que deseas que sea el vestido, y el ancho debe ser el doble de tu talla (cintura)
Picture #9 and Picture #10: Pin the fabric and then sew it together
Asegura la tela y pincha la tela para luego coser
Picture #11: Cut the excedent fabric
Luego corta el excedente de tela
Picture #12 and Picture #13: grab the lace and cut according to the skirt, to have the same measurements
ahora con el encaje mide y corta de acuerdo a la falda.
Picture #14 and Picture #15: Then sew the lace
Luego cose el encaje
Picture #16: place the lace and fabric like you see in the picture and safe with pins the elastic band.
coloca el encaje y la tela como puedes ver en la imagen y asegura con alfileres la banda elástica.
Picture #17: Then safely sew the elastic and fabrics
Luego cuidadosamente cose el elástico y la tela juntos
Picture #18: Would look like this :)
Te quedará así :)
Step 4: Third Step
The last Part!
Picture #19 and Picture #20: Now unite the top and skirt, and then sew
Unir el top y la falda para luego coser
Picture #21 and Picture #22: Add a belt with the lace, right on the waist line :)
Agrega un cinto con el encaje, bien en la línea de la cintura :)
