This should not be considered the only way to make a nice wooden sword, but it definitely makes a nicer one than you can usually find. Most of the work can be done with hand or power tools. The blade itself requires the use of a tablesaw.
As such the usual disclaimers are invoked. The use of tablesaws and other power tools can be dangerous. Take appropriate safety precautions and if something seems unsafe to you, stop.
Remove these ads by
Signing UpStep 1Step 1: How to make the blade
Rip a piece 1 3/4" x 1" x whatever length you desire (I ripped 48" pieces and later cut them down to 24").
When you've cut all your pieces (if you're making more than one sword) change the angle on the tablesaw to approximately 15 degrees.
You will be making four (4) rips.
Follow along with the picture (crude, I know).
1st cut will give you your first bevel. It should be exactly in the middle for the part of the sword blade in the air, and slightly past the middle for the part of the sword blade resting on the table.
The idea is to get a crisp bevel on what will be the side of the blade and a small (1/8") flat spot on the "edge" of the blade. Less chance of a horrific injury when the kids are playing with the swords later. For the purpose of clarity we'll call the end now towards you "A" and the end that will be cut first "B".
For the 2nd cut, flip the piece so that the 1st cut is up and towards the fence. "A" is towards you.
For the 3rd cut you will flip the piece end-to-end so that "A" will now be cut first and "B" is towards you. 1st cut is still up, but away from the fence.
For the 4th (and last) cut, flip the piece so that the 1st cut is down towards the table and against the fence. You may have to adjust the fence a small amount so that the cut matches the other side.
You now have a sword blank. Cut it to the desired size.
http://www.thesimplefarm.com/2011/12/christmas-activities-on-simple-farm.html
Thanks for this.
Doug
Looks like you live a very similar life to us. My wife does a similar blog at http://www.cultivatingfood.com/ but she doesn't keep up with it as well as you!
Regards,
Michael
When you do, I hope you'll notice that I used the dowel to secure the pommel to the sword, not the handle to the blade. The handle and the blade are all the same piece.
As a professional woodworker (and knifemaker - I've had to make custom knives for my leatherworking) I consciously decided to make them the way that I did specifically so they would stand a lot of abuse and not break.
As a point of interest, 4 1/2 years later all of these swords are still being used (and abused) by my kids and their friends.The only breakage had occurred at the pommel, but I did expect that and was willing to accept that as they're decorative elements. The breakage happened to one of the pommels itself, which happened, I suspect, because their was a prior split in the pommel that got worse when exposed to the elements (my kids leave them outside).
As to the rapiers - since I don't have the inclination to make masks I purposely didn't make swords that required lunges ;) The thought of my kids poking each others eyes out kept coming up.
I want to make 2 swords that I can beat together for hours and they are fine.
My friend and i beat up 2 wooden swords in an hour or two to the point their almost unusable, and I want some wooden swords we can wack together for hours on end and they'll be fine.
Don't use Pine or Birch, and definitely don't use a 2x4 from Home Depot, etc.
Ash, White Oak, Red Oak, Hard Maple, Hickory, Mahogany, Cherry and Walnut are good choices.
Have fun!
I have been doing stage combat for 2 years now and I know a functional practice sword and dagger when I see one. We use stage steel blades for actual combat and for new members we used wooden and polypropaline blades. These are really nicely crafted blades you have here.
If you ever were up for donating a few of them let me know, I'd be glad to have them in my troupe.
Kind Regards,
Jake
Kaji952000@yahoo.com
