3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a paintball silencer
#############################DISCLAIMER########################################
####I am not responsible for any injuries deaths or felonies you cause with this device.#######
Well, I basically took this idea and ran with it.
http://www.instructables.com/id/Make-a-silencer-for-MOST-paintball-gunsmarkers/
I updated it and fixed where he left off. It works well and its fairly light depending on what kind of PVC you use.
Step 1THE GOODS
THE GOODS
  • last photo ←
*1* Pocket knife
*2* PVC slightly larger than your barrel
*3* PVC 1" larger than your barrel
*4* 2 PVC reducers that fit your PVC
*5* Drill with a dremel bit
*6* Paintball marker
*7* Cotton balls
*8* Black plastic spray paint
*9* Sand paper
*10* Hammer
*11* PVC cutter
*12* Hacksaw
222 comments
1-40 of 222next »
May 2, 2012. 11:41 AMilpug says:
All the legality arguments aside, this is a paintball gun.
Real silencers use vented barrels and a system of baffles.
The attached cross-section design is a much more efficient design than what you used, and will work better and take up less space, as it can be extended back along the barrel in order to save space. It can also be a smaller diameter of pipe than what you used. Go grab a cheap barrel some time and see if this design works better. I reccomend using a cheap barrel because you have to drill a lot of vent holes in the barrel itself. This is kind of a non-removable design, so it is more of a silenced barrel variation. Note the slanted inward front- that helps it catch as much escaping gas as possible.
May 13, 2012. 3:02 PMrogerdemin says:
How many suppressors do you own?
A suppressor is under federal law is a FIREARM. If you make one even for a paintball marker you risk major fines and 10 years in jail.
Atf rulings right here for you who think they know the law.
http://www.atf.gov/firearms/faq/national-firearms-act-firearms.html#paintball-airgun-suppressers
Unless you have a letter form the ATF saying your design is NOT a NFA item OR you have a form 1 or form 4 for the item then your gonna go to JAIL when caught.
May 13, 2012. 8:18 PMilpug says:
I was aware that they were illegal, but I had not read the actual literature on that. Thanks for the link.
I used to own a silencer I made for an Airsoft pistol that I saw on this site, from cheap plastic pipe. Frankly, I don't care. I am aware of the law, and I am aware that it applies to me, and I am further aware of the fact that if I am caught I will be punished. I am also aware that some people may think less of me for making a silencer for a low-powered Airsoft gun. Still don't care.
Thank you for your concern. If the above graphic is illegal or needs to be censored, by all means flag it. Just consider the fact that there are many websites where you can find fully detailed instructions on how to silence all kinds of real firearms effectively. I have seen many movies that also show methods of silencing guns, there for any person to see. The above graphic is something that I thought up in about two minutes and drew on MS paint. I did it for the benefit of paintballers who want a silencer.
Also, thanks for your double post, but I heard you the first time.
Mar 12, 2009. 1:27 PMNInja99 says:
A real silencer has holes in in it. =]
May 2, 2012. 11:13 AMilpug says:
A real silencer does not have to have holes in it. Depending on the design, there may be vent holes in the barrel, or not. Usually silencers use baffles to catch escaping gas.
Mar 12, 2009. 1:32 PMNInja99 says:
but the picture at the beginning and end doesnt look like theres holes in it
Jul 8, 2008. 5:39 PMrotinom says:
Just as an FYI, if you live in the US, these are (generally) not permitted. You'll need to get a Class 3 tax stamp, pay $250 to register it, get permission from your local police department, etc.. This is because it is essentially no different from a silencer for a real firearm. Just something to be aware of, because it's a federal crime. Felony. Bad business all around. Otherwise, nice work. I'm assuming that the PVC pieces were not glued together, because otherwise splatter & everything would be a royal pain to get out. Also, you'll need to replace the cotton balls every so often. You may want to try very fine mesh steel or stainless steel wool, and check the performance. It'll be a bit more durable, but you will have the rust issue to contend with.
Jul 5, 2011. 3:11 AMrogerdemin says:
Once again someone who has no understanding of the laws in the USA giving BAD/ WRONG advice. First as I have already stated there is no 250.00 dollar tax stamp! There are two denominations a 5 dollar and a 200 dollar. Suppressors require a 200 dollar stamp I have a pile of them. You do not need permission form your local pd they juts have to sign off your not a bad guy of course folks like me who have a NFA ( national Firearms Act ) trust do not need to get the local le to sign anything nor do we need fingerprint cards.
Almost EVERY state allows suppressors and Machine guns.
It is not a class three stamp!! It is a tax stamp. The person who sells NFA items much have a FFL ( Federal Firearms license) and to sell NFA items they also require a SOT ( Special Occupational Tax ) these like the FFL come with different numbers that determine what they can do IE sell make or import or combination of.
In short a suppressor without a tax stamp is ILLEGAL if it can be adapted to a firearm. IE the models of airguns with suppressors made onto them are not illegal and require no stamp.
IF you are at all unsure or are not dealing with a FFL SOT then go to ATF.GOV and submit your question to them. The majority of answers here are blatantly wrong. The fact is not doing it right can get get you a felony on your record Jail time and a major fine to boot. Make sure your doing it legal BEFORE you even think about building one. EVEN A PART of a suppressor is illegal to posses without a tax stamp in hand.
Oct 7, 2011. 7:55 AMOruKun says:
I say i have a right to make stuff and do with it as a will as long as it does not hinder anyone else right to life, liberty , and pursuit of happiness. The pursuit of happiness from winning a round of paintball with me can and will be denied =}.
You just have to play the constitutional rights card and I didn't hurt nobody but myself when i was poking holes for my paint suppressor so don't tread on me Uncle Sam! And Come and take it ! (no don't actually...)
Jul 1, 2011. 2:41 PMcantrell8 says:
actually they are not illegal because you can buy barrels that silence
Apr 23, 2011. 7:00 PMThe3rdPunch says:
officially, they are called paintball "markers" not guns. They are used in a recreational sport which is about as illegal as baseball or football. Making a silencer is like drinking a gatorade meaning, it gives you the upper hand for about...12 seconds...
Sep 19, 2011. 12:44 PMxXxMattThePossumxXx says:
i'd say that they give no upper hand at all
Sep 19, 2011. 2:01 PMThe3rdPunch says:
You know that was a joke xD
Sep 19, 2011. 9:41 PMxXxMattThePossumxXx says:
if i didnt think it was a joke i'd have been more butthurt
Apr 21, 2011. 1:37 PMrogerdemin says:
There is no such thing as a 250.00 dollar tax stamp! There are only two denominations 5 dollar and 200 dollar. Most states do allow suppressors and machineguns and other NFA firearms.
That said a possession of a suppressor OR suppressor parts without a form 1 or form 4 is illegal. That's right simply owning a single baffle is illegal. Even if you own a suppressor ( I own several in many calibers ) spare parts are illegal.
There is ONE way around going the tax stamp route ( form 1 make your own or form 4 buy one already made ) you can make the suppressor as part of the paintball gun or bb gun. If they are made as part of the gun this means they can not be removed then they do not require a tax stamp. Gamo and several other airgun makers now sell there pellet/ bb guns with integral suppressors that do not require tax stamps.
These apply to the USA only I know nothing about other countries laws nor do I care as I do not live there.
May 15, 2010. 10:56 AM120012 says:
 exactlly : FIREARM is considered anything that uses a primer and a flammable source to push a object out of a barrel like an air rifle they have silencers that work on them but no tax stamp. SO THERE FORE THIS IS LEGAL.
Oct 5, 2010. 12:36 AMiriyejm says:
Sorry; It's the device not the "weapon" it's attached to.
possession of the silencer it's self is the element of the crime.
Jul 9, 2010. 9:14 PMSomeguy44 says:
and Co2 isn't flammible? okay, go throw some cans in a fire and watch from a safe distance with barriers around the fire, co2 is very flammable in the form used in paintball, and its explosive as all heck
May 2, 2012. 11:04 AMilpug says:
CO2 is what is used in FIRE EXTINGUISHERS.
Oct 7, 2010. 6:20 AMcarpe_noctem says:
wow ok then....ummm i'm pretty sure your referring to an occasion where you put a paintbal CO2 cylinder in a campfire. If it blew then it wouldn't be because the co2 burned but where the gas molecules got all excited from the heat and the pressure became to much. immediately after the blast the fire probably died down, right?
Sep 1, 2010. 9:25 PMkutz says:
dear jeezus lord CO2 ISNT FLAMMABLE xD
Aug 3, 2010. 9:55 PMtj the gnome says:
lol Co2 is used in fire extinguishers. :\
Jul 28, 2010. 6:51 PMBowHunter4life says:
Co2 it self is NOT flammable it has no oxegen in it wich fire needs to live so there for Co2 would put the fire out it is the fact that the canisters are pressurised ...and a FIRARM means anythin that uses a primer and a flammable source W/ Combution in the chamber. to expel a projectile
Nov 24, 2010. 1:40 PMsnowluck2345 says:
Well, CO2 has oxygen in it, however a chemical reaction would have to take place to release the O from the C
Jul 12, 2008. 11:37 AMeldorf_dragonsbane says:
Rotinom is correct, if this paintball suppressor can reduce the sound by even a decibel it is illegal to build in the US, if you do build this you are playing with some bad Mojo. Now its not illegal to have all the materials and plans for building a suppressor (depending on your local laws). You can even buy real firearm suppressor kits without having to pay the $250 tax stamp and getting your LEO to sign off, as long as you do not assemble the kit (or materials for a homemade suppressor). The moment you do you have committed a felony if you haven't went through the whole process of registering it with the ATF and getting the LEO permission. BoxHard further down from Rotinoms post you ask if this would actually work on a real firearm, the short answer is yes, i am not going to go into the long answer but lest just say it involves some modifications to the materials.
May 2, 2009. 6:02 AMminerug says:
There are no laws against the ue of silencers in New Zealand..
Jul 19, 2008. 7:55 PMcomander01 says:
What if you live in Canada?
May 23, 2011. 6:35 AMmathieulj says:
I had quickly looked into this and it looks like were out of luck too. Apparently the mere fact that someone could adapt it to a gun make it illegal here. If anyone has a video of a 50 cal (near the right diameter) firing through this, please post it so i can see the silencer explode...
Mar 30, 2012. 8:22 AMTheAntiHeroHimself says:
I know it's been a crazy long time since you posted this comment, but on the show Sons of Guns, on the Discovery Channel, they DID silence a .50 cal sniper rifle.
Look it up.
Mar 30, 2012. 9:50 AMmathieulj says:
I watched that episode a little while ago.
Notice the major differences between the two. Red Jacket used machined aluminium (most likely aircraft grade like the 7075 alloy) that, if done right, could hold up to very high pressures (like thousands of psi depending on wall thickness) were as this one is made out of PVC witch is only rated at around 90psi. PVC is also relatively brittle so an impact such as the gun firing would likely destroy it before it even muffles a single shot. As an added bonus, when pressurized with a gas, PVC has a nasty habit of exploding into shards like glass.
Jul 9, 2008. 12:01 AMpickford78 says:
Paintball guns are permitted in municipality and are not considered a firearm. I have had to deal with police and tell them that i am right and won the fight there. Silencers on these guns are perfectly fine and legal.
Sep 6, 2008. 2:46 PMShut Up Now says:
i believe it depends on county and state policies. just liek airsoft. here, people that wanna airsoft in public have to go to the next county lol. only a half hour drive tho
Sep 6, 2008. 8:16 PMpickford78 says:
Not in Canada :)
Jul 9, 2008. 7:13 PMcarpe_noctem says:
i live in chicago and paintball guns are VERY ILLEGAL not that it deters anyone that does it.
Oct 5, 2010. 12:40 AMiriyejm says:
But can't you just use your tommy gun??
Jul 9, 2008. 10:04 AMmadhops0620 says:
no, thats not true. These silencers are illegal. They were outlawed by the Bureau of ATF in the late 90s because they realized that these can be used on real firearms. look it up
Sep 18, 2009. 3:43 AMViator77 says:
You're right on the legality issue, but unless a L.E. representative has it out for ya, common sense would tell him/her that this device is for paintball markers only. Just think of how absurd someone would have to be to use a PVC silencer on an actual firearm. Considering the size of this device, it wouldn't dampen the noise from anything less than a .50 cal. Can't wait for that video to pop up on youtube: a PVC silencer blowing to shreds when some Darwin-Award recipient places one at the end of a large-caliber rifle.
1-40 of 222next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:MrAngryPants
Creative 125 year old who spends his extra time making things. Sucks how I don't document everything I build.
