This planter also has a vertical feature. I did not just want to leave that end covered up, so I fashioned a way to plant some sedums on the vertical face of the planter.
If you don't know folks who work in a science lab at a university, you might not come across suitable pieces. If you live near a university, however, you can always swing by the garbage outside of physics, chemistry, or engineering labs once in a while; often you can find some quality junk waiting to be thrown out.
Remove these ads by
Signing UpStep 1Find some junk
My junk was formerly part of a plasma generating ring, seen here. This is a nice shape because you could place it in a number of ways: as seen in the picture, or on its rounded side, in which case you'd leave the rectangular plate on top and have plants growing out of the two circular ends.
What else you'll need:
Enough rocks - the amount of rocks needed depends on your planter size
Enough dirt - the amount and type of dirt depends on both your planter size and your plants' preferences
Some plants - enough to fill the space
Wire mesh - some fine mesh (window-screen mesh) and wider, stiffer mesh
If you have a vertical hole, you will need some kind of clamps or glue
Planter base
Caulk
Thanks for the great idea!!
