How to make a plastic bottle shuttlecock!
This is a instructable on "how to make a plastic bottle shuttlecock", it involves cutting the neck of the bottle off, and cutting the plastic (curvy top bit) into "feathers", It works relatively well for a DIY shuttlecock, but a bit heavy and has a dodgy flight pattern. This is a very simple instructable, but the cutting of the feathers is quite fiddly. There is a video of the final shuttlecock being served, this is on the final step! Good luck and experiment with it!
( vote for me on feb 2nd onwards, i want a solar bag! )
Step 1What you need!
What you need!
A plastic bottle - To form the shuttlecock from
Scalpel or Craft knife - To separate the neck and body, (scissors really don't work here)
Scissors (smaller the better) - To cut the feathers, (craft knife really doesn't work here)
Masking tape - To pad the shuttle's base
Fingers etc - to handle all above
8 comments
Jul 9, 2011. 11:03 PMdenniSinned says:
what racquet do you use?
Apr 11, 2009. 11:59 AMUncle Kudzu says:
not a bad idea, seeing as how a heavy-ish shuttlecock is not easy to find in some locales. may have to try this. i must say, however, that you might want to consider some better pictures to go along with your good idea.
Jan 10, 2009. 7:33 AMcsmiler says:
it might be bad for the racket
Jan 8, 2009. 1:28 PMChicken2209 says:
very cool how does it work?
how well*
Jan 9, 2009. 10:07 PMwiley coyote says:
You could add bounce and stability by putting a cross section of Super Ball on the cap. The extra weight in the nose should make it fly farther and straighter .... I think.
Jan 8, 2009. 4:21 PMpaulpcc says:
interesting :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jackcday
