3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a poster sized (high quality) tiled image for under $5!
Have you ever wanted to get a poster of your favorite photo printed? I have. But I'm broke. Then I realized that you can make a very good looking poster sized image using a bunch of 4 x 6 photos.
Step 1Materials
Materials
-16  4 x 6 photos (from cvs, walgreens, etc...)
- Foam poster board (I used 22 x 28)
-Computer paper
-Straight edge
-Ruler
-Pencil
-Elmer's spray adhesive glue
33 comments
Jan 12, 2012. 2:22 PMomalachowski says:
Great 'ible!
I want to mention that if you take your photos to a drugstore or instant shop, you should tell them to turn the color-correction off on their machine. Many of the instant-develop machines hit your photo with an auto-contrast, and each of the photos will come out differently, which will cause a weird look when assembled.
As for spacing, a drafting table with guide would be key to getting good lines. If you don't have one, maybe you could use tile spacers?
-Olaf
Jan 9, 2012. 7:41 AMLeahYeah says:
to divide the image... i would make a 4x6 document... and i would paste it onto your image... then id duplicate it a few times...
select the layers and use the align tools to make sure its all accurate... then all you have to do is hold ctrl and click on each of the 4x6 layers and hey presto you have selections and all :)
ok after reading over my post i understand this sounds like a lot of trouble... but thats what id do... because i absolutely hate measuring and re measuring things only to find out in the end ive got the measurements wrong xP
Jan 12, 2012. 10:47 PMdBrez says:
THIS IS AN AWESOMAZING POSTER! Perfect for empty wall spaces or just a taste for something different and not too mainstream. Thorough instructions and great attention to detail; beautiful finished product. Well done! :D
Jan 9, 2012. 7:44 AMLeahYeah says:
ahhh... i love this as a gift idea.....
its something thatdoesnt cost a lot of money... but isnt cheap and thoughtless....
thanks for sharing!!
Jan 12, 2012. 9:13 PMpravs2k says:
Beautiful.I'm going to try this though I am not very computer savvy.
Did you use a sealant after every thing was in place? I mean like Krylon spray matt varnish.Do you think it is necessary to protect the surface?
The tile effect is really very attractive.In fact I thought it was done on tile and thats why I opened this site first before checking all the others.
Thank you for the very clear instructions.
Jan 12, 2012. 6:24 PMDoganie says:
It looks really good, but I think you might have accidentally switched the two middle tiles in the far left column.
Jan 12, 2012. 9:39 AMagis68 says:
very nice instructable....when i see the cat on the poster, u reminded me my beloved cat, wich we lost him from stroke....a couple of years now....i have same small pics under his favorite corner but this is what realy worth....I will make it as soon is possible.....thnx again
Jan 12, 2012. 7:51 AMletsneck says:
This turned out very nice. One comment though, if you look closely at the very last picture of the completed project, you will notice that two of the 4 X 6 photos are out of place. Can you figure out which two? I do a lot of photo editing, so I picked it out very quickly. Great work though. This is an easy way to make nice artistic enlargements.
Jan 12, 2012. 7:22 AMsusanrm says:
My home photo printer does a better job than CVS or Walgreens. Plus I can see if I need to make any adjustments at home. But nice instructable. I thought from the look of it that you had found a way to print them on tile, which would be ultra cool.
Jan 12, 2012. 2:39 PMredtiger2 says:
Some of the "photo quality" spray adhesives will dry in my desert climate and photos will peel off in a few months. I use a good spray contact cement and so far my mounts that are about 10 years old are not showing signs of coming off or deterioration. I pay under $6 for a 16 x 20 inch poster at S--'- Club. A 16 x 20 inch from other places in town can be $30 or more. I use the do it yourself kiosk at the club and get 1 hour prints. Very high quality and spectacular color. I have won awards at the state fair and a professional photographer who was a judge said my large prints were much better than where he had his done.This article inspired me to make a wall sized poster with 16 x 20 prints. Always remember that cropping, altering contrast and brightness are the 3 simplest and most important things you can do to make your pictures spectacular. For competition prints, size matters, if it is worth printing and you want to win, print big!
Jan 12, 2012. 1:04 PMtn. says:
*photo, even (not phone, that would be a whole other ible)
what about using lo-tack pinstriping, such as that used by painters? you can get them very thin (just a quick search and i've got 3mm, a little less than 1/8") use it to mark out the grid, apply adhesive to the phone but not all the way to the edge. once the photo has set, pull up the tape and secure the edges.
Jan 10, 2012. 12:12 PMzerfall says:
You may want to make your 6x4 image at 300 dpi. That is the right resolution for printing to scale as long as you don't have to up scale the copied layer too much it will look much better, as long as you start with a large enough image.
Jan 9, 2012. 5:57 PMmaazr says:
COOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOL :]
Jan 8, 2012. 8:49 AMmrg2k8 says:
Or, you could use the free piece of software called the Rasterbator, which saves you a lot of work in Photoshop. You only need a high-res picture.
Jan 8, 2012. 8:48 PMUncle Kudzu says:
But the Rasterbator doesn't produce a continuous tone print, if I'm not mistaken. If I correctly understand this instructable, one wouldn't see the pattern of large dots that the Rasterbator makes at close range with this method.
Jan 8, 2012. 11:42 PMmrg2k8 says:
You can choose the dimension of the dots. I did a 2.5 x 1 meters poster and the dots aren't visible when you look at it from ~1 m. Yes, the program processes your image slower, but it's it doing the job, not you in PS :)
Jan 9, 2012. 5:40 PMUncle Kudzu says:
Thanks for the correction, then. I have an old Rasterbator image on my wall and the dots are pretty big. Perhaps I should re-familiarize myself with that process before I write about it next time. Thanks again.
Jan 9, 2012. 8:47 AMbmelton1 says:
There is a website that allows you to do the same thing for free as well if you do not have photoshop. www.blockposters.com
saves the final image as a multi page pdf and allows you to take it to kinkos on a flash drive to use up all their color ink.
Jan 8, 2012. 8:41 PMUncle Kudzu says:
Nicely done and good instruction!
If you print a little overlap, there is a way to splice a photo like this so that the grid effectively disappears - a little like splicing wallpaper patterns to match up. But the grid has its own graphic appeal, too.
Jan 3, 2012. 11:34 AMCatTrampoline says:
Outstanding! I like that you gave clear directions on how to create the effect in PhotoShop.
I have a large blank wall that could use something like this for dramatic effect.
Jan 2, 2012. 6:56 PMbigwhitebear18 says:
I did a similar project on a slightly larger scale. I printed a panoramic I took on single-weight mat board 8x10s and hung them using Command strips. Now I have a massive 5ft x 2ft panoramic hanging on my wall. It isn't a straight as I would like but it looks good from a short distance. I'm sure yours is much straighter since it's on a smaller scale and a yard stick could be used to keep everything in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:michaelbain
I'm a high school cross country and track runner who enjoys making random things in his free time!
