Step 4Wire the module to the keyboard
Fire up the solder iron.
Cut two lengths of wire (about 15 inch each, preferably one red and one black), strip and tin them.
Cut the musical module switch away, you will replace it with the transistor.
Get the NPN transistor and hold it flat side up, pins away from you. Spread the pins apart.
- Solder the left pin to the positive contact of the battery.
- Solder the right pin to the other contact of the switch, leading to the music chip (big black blob).
- Solder the red wire to the middle pin.
- Solder the black wire to the same contact as the right pin of the transistor.
- Solder the other side of the red wire to the positive side of the LED.
- Solder the other side of the black wire to the negative side of the LED.
Add Comment
