Step 3Expose the presensitized circuit board to UV light.
Turn the UV light box on. We found that exactly 1 minute exposure time worked well. You may have to experiment with different times depending on the height above the LEDs. Turn off after 1 minute.
The photoresist will look exactly the same after it has been exposed to UV light. We could not tell the difference between an exposed board and a non-exposed board.
Note: The first time you attempt to make a PCB, you will most likely fail (we failed literally about 40 times. Darn textured transparency paper!). We suggest buying a large PCB and cutting it into small squares with a Dremel (I also read a paper cutter works fine). This will save you a lot of money.
comments
Add Comment
Add Comment
