3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a projection screen that's also a painting
How to make a projection screen that\
I had this idea that I would make a projection screen that doubled as a painting when you flip it over. I liked the thought that it would look like I didn't have a TV at all while at the same time getting a cool piece of art that I actually made myself. It turned out to be a lot of work but I'm very satisfied with the result even though a lot of things didn't turn out as I thought (some better, some worse).
Anyways, I thought I'd collect what I learned and publish it so that people can go ahead and make even cooler screen+painting combos.
Step 1Get the stuff
Get the stuff
First thing to do is to build the frame. I went to the lumber yard and got regular unfinished lumber (40mm x 30mm) to make the inner frame. I also got some finished wood to use as the outer frame. You also need some L brackets, wood screws, a staple gun and a miter box (if possible though, use one of those miter saws that are attached for better precision).
The picture is missing quite a few pieces, but you probably know what they look like anyway.
42 comments
1-40 of 42next »
Jul 24, 2008. 12:36 PMjaime9999 says:
so, how do you flip it around? from the description and initial photo, I was expecting a Kandinsky-like "double sided painting" mounted on some kind of rotating bracket. Here's how you could build such a thing: Like a Kandinsy, mount a rotating bearing at the exact center of the top of the frame, so the painting can spin in air. Then mount the other end of that bearing on an arm that is attached to the wall. The arm should be slightly longer than half the width of the painting, and itself mounted on a hinge (this hinge would be tricky to fabricate). Then, to rotate the painting, pull it out from against the wall (so the arm is perpendicular to the wall, spin the painting 180, then push back against the wall. Also possible would be a similar design where the arms and bearing are mounted on the sides, so it spins around a horizontal instead of vertical axis. The decision between these two options would have a lot to do with available space and clearances to other furniture and walls. Flyke, in your living room, where the painting-display wall and the screen-display wall are at 90 degrees, you could put an arm up against the ceiling, hinged at the corner where the walls intersected, and just hang the painting from the arm on cables (no need for a bearing on the painting frame).
May 17, 2012. 10:40 AMblackwellj says:
about £30000
Jun 28, 2011. 11:26 AMzigzagchris says:
I like the url of the page
Feb 8, 2012. 10:59 PMKryptonite says:
+1
Jun 19, 2011. 12:37 PMtinker234 says:
oh wow how good is the image
Sep 25, 2010. 1:43 AMeyerobot says:
Do you get any light bouncing from the back of your painting, And onto the projection screen?
I would imagine some light would try to bounce like that, But maybe your material is too thick for that.
Love this instructable, Thanks.
Jun 1, 2010. 3:38 PMallandnnn says:
instead of ruining your master piece you can make a sanding block with fine grit grab some wood filler angle the wood down so it is the only part pointing down use the wood filler let dry sand the corner down then paint it when i was working as a carpenter helper they did it a lot with filling holes on framing on 8 million dollar work boats might want to try on a practice miter angle till you perfect it first
Aug 14, 2009. 5:29 PMLunaBomb says:
This is awesome, but how'd you mount it to the wall?
May 21, 2009. 5:56 AMValche says:
Couldn't you just plane and repaint the corners?
Mar 7, 2009. 7:50 AMswatdoc says:
AWESOME instructable...do you think you could email me the artwork?
Feb 26, 2009. 12:01 PMOnTheLevel says:
Nice work! Thanks for the tutorial
Oct 21, 2008. 2:18 PMclintta says:
What program for editing the images did you use?
Jul 28, 2008. 12:09 PMHedgie says:
Not sure if you knew and just found them too expensive or what...but just in case you ever have to re-canvas the thing...I would definitely suggest a pair of painter's canvas stretchers...they'd certainly save your finger tips.
Jul 28, 2008. 1:44 PMHedgie says:
Yep, That's be them
Jul 25, 2008. 6:02 AMmattress says:
nice work, now I just have to get a projector. BTW, is that a braveheart sword on your wall?
Jul 25, 2008. 5:24 AMGreenehouse says:
Great job, thanks for the idea. One thing a painter told me on a jobsite was "caulk and paint make it what it 'aint!"
Jul 25, 2008. 3:45 AMslimguy379 says:
awesome Idea, I have an old set up projector screen that is horrendous and could be used for this idea. thanks... keep up the good work.
Jul 25, 2008. 3:26 AMEclecticos says:
Its a Steve McQueen Screen. Hell Yea. Looks Fantastic.
Jul 23, 2008. 4:17 PMhernanai says:
http://www.instructables.com/id/How-to-make-a-projection-screen-thats-also-a-pain/?ALLSTEPS
um... do you see anything odd about the link... that's what caught my attention... "also a pain"
Great instructable and i love the result...
Jul 24, 2008. 12:37 AMRishnai says:
Aren't most projection screens also a pain?
Jul 24, 2008. 4:23 PMhernanai says:
especially when they don't roll back up...
Jul 24, 2008. 6:06 PMRishnai says:
Or when they roll up right in the middle of watching something, especially something live, like NASCAR.
Jul 24, 2008. 9:46 PMhernanai says:
or a LAN party... like Halo 3 and your entire team is one the one screen... and your enemies are on another... one hell of a night...
Jul 24, 2008. 10:28 PMRishnai says:
Ouch! I like playing CoD 4, with one team on broadband and the other team on dialup. As long as both teams are good sports, it is great fun. Especially when you get a few flash-bangs going and make it a rave.
Jul 24, 2008. 9:13 PMnormalicy says:
Latex Caulk. It's what many carpenters use to seal the seams between the wall base trim in houses. You could also use filler putty, but it's a bit more fragile.
Jul 24, 2008. 1:50 PMrallen71366 says:
It is VERY difficult to make tight frame joints with a hand saw. I made a jig for my table saw to cut the picture frames. It's almost a necessity, as even 1 degree difference in the cutting angle shows up as a huge gap. The trick is to make a sliding table with a 90 degree block to back the strips against when pushing into the blade. Set the block so that it is bisected into 2 * 45 degree angles, before it is fastened to the sliding table. Then hold your frame pieces against the block and push. Even if the block isn't set perfectly, the angles will always match into a "perfect" 90 degrees.
Even this won't guarantee a "picture perfect" frame. (sorry, I had to!) Be ready to use some sandpaper taped to a block of wood and some wood putty to get the best appearance.
Fascinating design! I really enjoy it, and looking forward to more from you!
Jul 24, 2008. 3:39 PMearlyjp says:
The jig described above is indeed a good idea. However, you can make the joint stronger by using a spline. See this linkthis link. It describes how to do it using a table saw, but it can also be done with a handsaw. In fact, a handsaw is safer when the pieces you are working with are long, as in this Instructable.
Jul 26, 2008. 8:20 AMrallen71366 says:
Pre-built corner connectors are a very good option to hand building "picture frames". If the frames aren't visible (covered by canvas) you could probably use just use pipe and fittings. A painted pipe "frame" with a canvas "skin" stretched on it would be nice also. My late uncle (a pro artist) did an ink-on-chamois of a wolf, stretched inside a frame made of a looped branch. Very nice! The same idea with a more industrial flavor would also work well, I'm sure.
Jul 23, 2008. 9:13 AMThornburg says:
For that corner just get some wood filler, and sand it down. Then just paint over. Nice work.
Jul 23, 2008. 7:40 AMGjdj3 says:
That's really cool. You can have your big projector screen and not have it look ugly when it's not being used. 5 stars!
Jul 23, 2008. 7:24 AMcodester says:
Nice job!
Jul 23, 2008. 4:40 AMkillerjackalope says:
Nice 'ible, you can get Binding corners for boxes that look nice, they'd do well, they're usually galvanized steel...
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:Fylke
