3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a projection screen that's also a painting
Step 8Lessons learned
Lessons learned
I'm quite pleased with the end result, but it was a lot more work than I'd expected. The only thing that's still bugging me are the corners. I'm thinking of putting a piece of sheet metal around each corner to cover up the actual joint if I only can figure out how to make it look good. I will probably paint it black as well and would welcome suggestions on how to best make the paint stick to the metal.
Anyways, the joints on the inner frame and the outer one are really the only two thing I would have made different if I did it again. Now go forth and make even nicer paintings!
9 comments
Sep 25, 2010. 1:43 AMeyerobot says:
Do you get any light bouncing from the back of your painting, And onto the projection screen?
I would imagine some light would try to bounce like that, But maybe your material is too thick for that.
Love this instructable, Thanks.
Aug 14, 2009. 5:29 PMLunaBomb says:
This is awesome, but how'd you mount it to the wall?
Feb 26, 2009. 12:01 PMOnTheLevel says:
Nice work! Thanks for the tutorial
Jul 25, 2008. 5:24 AMGreenehouse says:
Great job, thanks for the idea. One thing a painter told me on a jobsite was "caulk and paint make it what it 'aint!"
Jul 24, 2008. 9:13 PMnormalicy says:
Latex Caulk. It's what many carpenters use to seal the seams between the wall base trim in houses. You could also use filler putty, but it's a bit more fragile.
Jul 23, 2008. 4:40 AMkillerjackalope says:
Nice 'ible, you can get Binding corners for boxes that look nice, they'd do well, they're usually galvanized steel...
Jul 23, 2008. 4:43 AMThe Urban Spaceman says:
I really like this idea, thanks.
Jul 23, 2008. 4:47 AMkillerjackalope says:
Look in the hardware store of nick a few off of some old wooden crates...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:Fylke
