3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a racing lawn mower (Updated!)
Step 18Re-doing exhaust, paint, brakes, and other stuff.
Finishing up
Something I realized right away was that the engine was reverse of what the old 12.5 engine had been: The starter, carb, and exhaust were all on the other side. At first I didn't think this would be that big of a deal. But the problem was that the new high torque starter stuck out so far on the right that it interfered with the brake pedal- which was on the left where the starter would now be. This meant moving the brake pedal and master cylinder to the left. This wasn't that difficult: The MC was moved to the left and new holes were drilled for its mounting bolts. The problem arose when I realized that with the carb on the left the intake was extremely close to the brake pedal. I didn't want to accidentally kick the carb when racing. After doing some configuring I simply welded an extension onto the end of the pedal making it wider. A piece of angle iron was welded to the top of the pedal. This ensures that my foot will not slip and wind up sliding close to the carb. After 2 races its worked out well.
 The exhaust was a bit tricky. Since the exhaust was on the other side it had to be cut so the bend could be reversed to face the other way. On top of that the exhaust port was higher up than the one on the engine. In order to accomplish the additional length I welded in a piece of pipe. A word of warning: Do not weld galvanized steel. The pipe I used was galvanized but I spent a great deal of time grinding this off. If you do weld Galvanized you can get very sick.
 The engine was then installed and the old clutch bolted on. This has been a fantastic clutch with over 3 years of use and hardly any wear. I did disassemble it and applied a very light coat of grease to the bearings. I also cleaned the shoes a bit.
 The new hood and fenders were sanded down and painted. I used Duplicolor high heat ceramic engine paint. For some reason I've found its one of the best rattle can paints for getting a nice smooth finish. The color I got is called " Cast Iron". Pretty cool actually, and different from what most people use on their racing mowers. Seems like crazy fluorescent colors are very popular.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:mowerracer
